Will a 2000 Itr Tb work with a 98 Gsr?
Old Jul 19, 2001 | 08:52 AM
Rhetoric's Avatar
Default Will a 2000 Itr Tb work with a 98 Gsr?
I was wondering if a 00-1 itr tb would work with a 98 gsr. I noticed on the itr tb there is like an inlet near the map and on gsr there is not?
Old Jul 19, 2001 | 09:39 AM
Mike K's Avatar
Default Re: Will a 2000 Itr Tb work with a 98 Gsr? (G S R)
If you have a Skunk2 manifold it'll work for sure, but I'm not sure if the ITR tb has the two holes drilled in the side to accept the GSR throttle bracket. I just sold the one I had in stock so I can't look and see. Sorry.
Old Jul 19, 2001 | 11:15 AM
importtuner's Avatar
Sure why not.
-importtuner
Old Jul 19, 2001 | 04:37 PM
Comtechgsr2000s's Avatar
New User
No it will not work. Look on your GSR t/b and notice how the t/b cable goes over the top. Well the type R one goies from the bottom. Don't get the JG t/b either.
I tried to get one and the check engine light came on and my car was running erractically. Cam getting type R cams and gears.
Old Jul 19, 2001 | 04:52 PM
Benjamin Tang's Avatar
Default Re: Will a 2000 Itr Tb work with a 98 Gsr? (Mugenblkgsr2000)
perhaps it's possible to fit the throttle cable assy on the itr? not sure how to wind the spring up though.
Old Jul 19, 2001 | 04:58 PM
DC2#309's Avatar
New User
Default Re: Will a 2000 Itr Tb work with a 98 Gsr? (Benjamin Tang)
it sure will work, but you need to get throttle wire too.
Old Jul 19, 2001 | 05:03 PM
Rhetoric's Avatar
Default Re: Will a 2000 Itr Tb work with a 98 Gsr? (DC2#309)
Thanks for the replys, I'm planning to use the Skunk itr manifold with this tb, but I was wondering about that inlet near the map sensor on the itr tb? If its a vacuum hose, where does it go? Thanks again
Old Jul 19, 2001 | 05:22 PM
Why use the Skunk manifold when its the exact replica of the ITR's? I'm just trying to save you some money man!
-importtuner
sanjiyan69
Dec 13, 2010 02:36 PM
Acura850.
Jan 27, 2009 11:25 AM
NosShootinHonda
Jan 9, 2009 05:38 AM
ej_b16a
Nov 30, 2007 12:27 PM
gsrboost
Jul 9, 2006 08:11 PM
