codes
Old Jun 10, 2003 | 01:16 PM
crxchris's Avatar
Default codes
i was wondering if any can advise me how to check my ecu for codes i did do a search to no avail
Old Jun 10, 2003 | 01:37 PM
Perfectionist's Avatar
Default Re: codes (crxchris)
Either you had to wade through a crapload of useless stuff, or you didn't search correctly. ANyway....
At least on the 4th gens, pull the carpet back from the upper toe area of the passengerside footwell. You'll see the ECU. Turn the ignition to ON, and count the flashes in the plastic window.
Old Jun 10, 2003 | 01:41 PM
DJ_SaNdOz's Avatar
pull up the carpet on the passenger floorboard, you will need to pull the outermost corner out & you will see a metal box on the floorboard w/ a little LED window- your ecu will flash the codes using that light. your car will at least need to be turned on to the accesory postioin to show codes. hth
Old Jun 10, 2003 | 02:41 PM
EL Vap133's Avatar
Here you go: http://www.teirney.net/civic/ECUErrorCodes.htm
Old Jun 13, 2003 | 05:55 AM
crxchris's Avatar
thanks for the help
Old Jun 13, 2003 | 09:28 AM
EL Vap133's Avatar
Default Re: (crxchris)
No problem...
bones72751
Apr 24, 2011 12:16 PM
jpar195
Apr 7, 2008 12:01 PM
Schaz
Nov 5, 2004 11:06 PM
7808
Jun 22, 2004 09:37 PM
madflava
Oct 15, 2003 11:18 AM
