What head should I use for LS/VTEC
Old Jun 10, 2003 | 11:29 AM
LSHatchback's Avatar
Default What head should I use for LS/VTEC
Hey, i've got a LS non v-tec getting ready to vtec it, what head would you guys recomend ? most people are sayin GSR around here.
Old Jun 10, 2003 | 11:31 AM
lilblacksol's Avatar
it depends on how far you wanna go with it!
Old Jun 10, 2003 | 12:15 PM
EVIL Hx Coupe's Avatar
Default Re: What head should I use for LS/VTEC (LSHatchback)
GSR or B16 head...
I've heard that the B16 flows better... Dont quote me on that....
Old Jun 10, 2003 | 12:16 PM
Ya@inlinePRO's Avatar
use a vtec one.
Old Jun 10, 2003 | 12:18 PM
GTlvr82's Avatar
Default Re: (kwik2nec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kwik2nec &raquo;</TD></TR><TR><TD CLASS="quote">use a vtec one.</TD></TR></TABLE>
What he said.....I am doing the same thing and am using the B16 (built though with Type AAAARRRRR cams and Ferrera valves and valve springs.
Old Jun 10, 2003 | 12:47 PM
akaEsCo01's Avatar
i'd say type r if you got the cash, but a gsr head will do
Old Jun 10, 2003 | 12:48 PM
137's Avatar
137
the one in my avatar? oh cylinder head
Old Jun 10, 2003 | 12:49 PM
civicsitek GanGsTa's Avatar
Default Re: What head should I use for LS/VTEC (137)
depends on what you want to do, a gsr head will give you higher compression off the bat than a b16/type r head, however the pr3 heads do flow better...its up to you. Some more info would be helpful.
Old Jun 10, 2003 | 10:38 PM
Default Re: What head should I use for LS/VTEC (civicsitek)
I just want the most power for around 2100 installed... I know I probably can't get a C5 head for that installed, but ive got some quotes for 1700 ish for a C1 head... I just want the most for the money.. Don't really have a lot to build the head right now either, just put a stock head in.
p.s, obviosuly im going to be using a vtec head.. duh ..
Old Jun 10, 2003 | 11:30 PM
Eyes Only's Avatar
i would reccomend a type r head for the job cause my boy runs it on his civic and and it hauls
Old Jun 10, 2003 | 11:39 PM
IWearMyKswiss's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSHatchback &raquo;</TD></TR><TR><TD CLASS="quote">I just want the most power for around 2100 installed... I know I probably can't get a C5 head for that installed, but ive got some quotes for 1700 ish for a C1 head... I just want the most for the money.. Don't really have a lot to build the head right now either, just put a stock head in.
p.s, obviosuly im going to be using a vtec head.. duh ..</TD></TR></TABLE>
hold up hold up hold up,...2100 is for the motor AND installed on your car right??? and 1700 ish is for the whole LSvtec motor right,..if its 1700 just for the head your gettting RIPPED,...and if its 2100 just for installation,..your gettting ripped again,...clarify your post please
Old Jun 11, 2003 | 02:41 AM
EddieHatchBlack's Avatar
Default Re: What head should I use for LS/VTEC (Zex_Nitrous)
I say Type-R, and when you don't feel like LS-VTEC anymore, get a Type R block.
Old Jun 11, 2003 | 11:38 AM
Default Re: What head should I use for LS/VTEC (WiDeBoDyEK)
thats how much ive been quoted at 3 places for the head, manifold and everything installed.
Old Jun 11, 2003 | 11:45 AM
navin's Avatar
cheap, bare b16 head
portflow port + polish
new valvetrain + cams
Old Jun 11, 2003 | 11:48 AM
ramv8's Avatar
Default Re: What head should I use for LS/VTEC (navin)
one said vtec.. i hope
Old Jun 11, 2003 | 11:57 AM
rlstabber's Avatar
Default Re: What head should I use for LS/VTEC (ramv8)
get a old school b16 first gen head, you can get them cheap. send it to portflow, and youll still be under 1700. thats what im in the process of doin.
Old Jun 11, 2003 | 12:20 PM
slowdx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicsitek &raquo;</TD></TR><TR><TD CLASS="quote">depends on what you want to do, a gsr head will give you higher compression off the bat than a b16/type r head, however the pr3 heads do flow better...its up to you. Some more info would be helpful.</TD></TR></TABLE>
I agree with this statement.
Old Jun 11, 2003 | 01:16 PM
Quad-Damag's Avatar
Default Re: What head should I use for LS/VTEC (slowdx)
B16's head flow the most, don't waste your time on a GSR or Type R Head, a B16 head is one of the best to use with a LS/VTEC + it's the cheapest
Old Jun 11, 2003 | 01:35 PM
slowdx's Avatar
Default Re: What head should I use for LS/VTEC (Quad-Damge)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Quad-Damge &raquo;</TD></TR><TR><TD CLASS="quote">B16's head flow the most, don't waste your time on a GSR or Type R Head, a B16 head is one of the best to use with a LS/VTEC + it's the cheapest</TD></TR></TABLE>
Yeah dont waste your time on a type r head cause b16's flow the most (just givein ya a hard time you were saying it like b16 head flows more than a type r)
If you can afford type r go for it. When your bulding your motor you can get pistons to whatever spec you want so you dont have to worry about the compression ratio being lower with a pr3 head.
You can also get your type r or b16 head milled to up the compression a little more.
I would either get a b16 and build it with ferrea valves, skunk2 springs and retainers and skunk 2 cams for amild all motor application.
Or get a type r and keep it a stock head maybe with a good set of cams. Or you can bild t and sell the stock parts anf gain some of yor money back. Just depends on what deals you can find.
just my .02
Old Jun 11, 2003 | 01:51 PM
I Kick Squirrels's Avatar
anything but a gsr head.
Old Jun 11, 2003 | 02:00 PM
SkyeC's Avatar
Boba Connoisseur
25 Year Member
Default Re: What head should I use for LS/VTEC (Hatch-N-si)
Could someone provide facts as to why the pr3 heads are better than the p72 heads?
Old Jun 12, 2003 | 10:22 AM
slowdx's Avatar
Default Re: What head should I use for LS/VTEC (SkyeC)
I dotn really know where to look for "facts" how the pr3 heads are better that p72.
Facts are.
pr3 flows better stock vs stock and even ported p72 vs stock pr3 is close.
but the p72 gives higher compression
stock IM's are better on pr3
This is just my .02.
Old Jun 12, 2003 | 12:01 PM
coyotes fan's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slowdx &raquo;</TD></TR><TR><TD CLASS="quote">
That is totally wrong. Look at the flowcharts at http://www.alaniztechnologies.com
B-JUSTINE
May 26, 2006 02:38 PM
cars101
11
May 3, 2006 04:56 PM
siblueteg
Mar 31, 2005 06:45 PM
wilkerson05
Jan 9, 2005 05:56 PM
spoon063
Apr 11, 2003 01:22 PM
