skunk2 intake manifold install
Old Jul 19, 2001 | 07:53 AM
Go Mifune's Avatar
New User
Default skunk2 intake manifold install
1) my gsr aem cai won't fit? really?? are you sure???
2) this site < http://tiiite.b16a.com/sk2intake.htm > (which is unfinished) says i need a bunch of parts like ITR throttle cable, bracket, pulley. true? mandatory??
3) any other hidden glitches/problems i should know?
tia
-g
Old Jul 19, 2001 | 10:00 AM
rockwilda's Avatar
Default Re: skunk2 intake manifold install (Go Mifune)
1)no it wont fit...get an intake from an ls or a ITR
2)nope you can use your stock parts
3)-the throttle cable will hang a little high, but wont be any problems with that unless it really bothers you, just get a bracket from an SI i believe.
-its a B!tC# getting the GSR intake manifold out...
-wont do much on a stock engine..
Old Jul 19, 2001 | 10:20 AM
Go Mifune's Avatar
New User
Default Re: skunk2 intake manifold install (da_rockwilda)
thanks for the reply. yeah, i've heard about how hard it is to get the old one off. that's why i'm gonna have someone else do it (he's pulling the head anyway, maybe that'll make it easier somehow). stock? friends don't let friends drive stock! (intake, throttle body, head p/p, milled, jdm itr valvetrain, cam gears, pulleys, chip, headers, exhaust, clutch, etc. etc.)
Old Jul 19, 2001 | 10:57 AM
stretracr's Avatar
Actually you can use your old cai and throttle linkage I did it on mine. You will have to modify your cai though. Mine was a little easier since it is a iceman. But you will have to cut it a bit. The gsr throttle linkage just barely fits below the hood so you will be ok.
2k1 SSM GSR
Nov 2, 2004 11:44 AM
IN VTEC
Jul 9, 2003 12:21 PM
I B Z
May 21, 2003 01:44 AM
GSRfoedoe
Mar 26, 2002 01:47 PM
comptechgsr
Nov 10, 2001 09:12 PM
