Sticky Hood Release
Old Jun 10, 2003 | 08:08 AM
Eggman's Avatar
Default Sticky Hood Release
On my EF, releasing the hood is kinda tough. I swapped out the latch with another used one, and same problem. Don't see how it could be the cable though. Could it be the cable or the latch?
Old Jun 10, 2003 | 08:40 AM
REDBARON's Avatar
Default Re: Sticky Hood Release (Eggman)
What do you mean by, "Tough"? Give a better explanation.
Old Jun 10, 2003 | 08:42 AM
Artful Dodger's Avatar
I've got the same problem, I just sprayed wd40 on and it lasted about a month and a half, just last night i sprayed some silicon lube on and it seems to be working well
Old Jun 10, 2003 | 08:43 AM
Eggman's Avatar
Default Re: Sticky Hood Release (REDBARON)
It takes more force to pull the release than it does on my sis's Accord and my friend's Integra. And both those other cars are cable releases too.
Old Jun 10, 2003 | 08:47 AM
REDBARON's Avatar
You probably have the hood too tight. Just open the hood, and turn the adjuster so that it comes out a little. The adjuster I'm talking about is the metal rod by the spring on your hoodlatch. It has a slot in it so that you can turn it. Turn it so that it comes out a little. That should do the trick.
Old Jun 10, 2003 | 08:51 AM
Eggman's Avatar
Cool, I'll try to adjusting it later today. Thanks.
Old Jun 10, 2003 | 09:17 AM
raene's Avatar
On mine, there was a break in the cable It was so hard to open I had to use a pair of pliers to pull the wire to open the hood! And it wouldn't close half the time, either. After replacing the cable, it was nice and smooth again
Old Jun 10, 2003 | 09:20 AM
EL Vap133's Avatar
You haven't pushed your rad support up by hitting a big bump or anything? What I do is I push down on my hood and then pull the release cable and it opens up ok...
Old Jun 10, 2003 | 09:23 AM
Eggman's Avatar
Default Re: Sticky Hood Release (Vap133)
Hahaha. I've seen a lot of EFs that had to do that. But not mine,...not yet.
Old Jun 10, 2003 | 10:09 AM
REDBARON's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Vap133 &raquo;</TD></TR><TR><TD CLASS="quote">What I do is I push down on my hood and then pull the release cable and it opens up ok... </TD></TR></TABLE>
Mine was like that too. I adjusted it, and now it opens without me having to do that.
efjones9
Jan 11, 2009 01:04 PM
EJ1Dream
Jan 3, 2007 07:04 PM
B2FiNiTY
20
Apr 28, 2004 01:25 PM
naterpatater77
Feb 29, 2004 05:32 PM
cannan
Dec 28, 2003 09:40 AM
