after zc swap one wire without a home located around oil filter/alternator, please help
Old Jun 10, 2003 | 07:56 AM
VTgringo's Avatar
Default after zc swap one wire without a home located around oil filter/alternator, please help
anyone ever had this problem? i have one connection left to be made but i can't seem to find where it goes. sorry this isn't too specific about which wire i thought maybe someone else has had this problem. the wire comes off around where the alternator wires are. My car is also is idling very low when i push in the clutch.
thanks guys
Old Jun 10, 2003 | 09:00 AM
Ronin Panda's Avatar
Default Re: after zc swap one wire without a home located around oil filter/alternator, please help (VTgring
i got the same thing bro....the wire colors of the wire i have left over are :
orange and black/yellow.
whats chassis is the zc in? dohc zc?
i think the left over wire is normal..my car runs fine
Old Jun 10, 2003 | 09:15 AM
slooogsr's Avatar
i didnt have any left cept for ac fan wiring ......... i will check again but i have the hf model.
Old Jun 10, 2003 | 11:30 AM
FourthGenHatch's Avatar
Default Re:
Is it one single wire or a wire harness plug? I have one white colored harness plug that was left over, it plugged into something the DX had that the ZC does not.
Old Jun 10, 2003 | 11:46 AM
DJ_SaNdOz's Avatar
Default Re: Re: (FourthGenHatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FourthGenHatch &raquo;</TD></TR><TR><TD CLASS="quote">Is it one single wire or a wire harness plug? I have one white colored harness plug that was left over, it plugged into something the DX had that the ZC does not.</TD></TR></TABLE>
i have the same thing, but I have an Si model.
Old Jun 10, 2003 | 11:58 AM
blah13's Avatar
Default Re: Re: (DJ_SaNdOz)
Its normal, you will have 1 plug leftover.
Old Jun 10, 2003 | 12:44 PM
gregv's Avatar
Default Re: fast idle solenoid
it's for the fast idle solenoid, which kicks in at -10C. You should have two wires left over;
tape them up and tuck them away, you don't need them on the ZC. Then again, mine idles
like crap.......
Old Jun 10, 2003 | 01:01 PM
DJ_SaNdOz's Avatar
Default Re: fast idle solenoid (gregv)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gregv &raquo;</TD></TR><TR><TD CLASS="quote">it's for the fast idle solenoid, which kicks in at -10C. You should have two wires left over;
like crap.......</TD></TR></TABLE>
Mine too & I can't figure it out- I know it desperatly needs a valve adjustment, but damn does my idle suck. sorry- a little OT
Old Jun 10, 2003 | 04:29 PM
slooogsr's Avatar
mine idles pretty smooth....... try adjusting the timing on the distributor a bit and if u have a pressure regulator play around with that......... ive noticed alot of diff in it
williamcollins
Jul 8, 2017 01:24 PM
D16Z6racing
Audio / Security / Video
Mar 21, 2007 05:56 AM
lukedatwin
Aug 11, 2004 07:51 PM
onestyle
Jul 7, 2002 07:23 PM
