Mount Toda flywheel
Old Jun 10, 2003 | 05:53 AM
paulITR's Avatar
Default Mount Toda flywheel
I own ITR and I'm going to mount Toda flywheel and clutch kit.
Stock flywheel has mounting mark on, but the Toda hasn't, there is only a white mark on the flywheel and clutch cover.
Any advice about how the flywheel has to be mounted on the crank?
Old Jun 10, 2003 | 05:56 AM
Willard's Avatar
Default Re: Mount Toda flywheel (paulITR)
which ever way you would like.
did you get the balanced clutch kit?
Old Jun 10, 2003 | 06:02 AM
paulITR's Avatar
Default Re: Mount Toda flywheel (Willard)
Yes I got the balanced clutch kit and the white mark on the clutch cover and on the flywheel signs their assembling position.
But are you shure that flywheel has not a fixed position on the crank too?
Old Jun 10, 2003 | 06:06 AM
Willard's Avatar
not unless you balance the flywheel/clutch assembly with the crank.
Old Jun 10, 2003 | 06:13 AM
paulITR's Avatar
But does the stock crank/flywheel come balanced from the factory or not?
And might I balance the Toda on the crank?
Old Jun 10, 2003 | 06:38 AM
Willard's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by paulITR &raquo;</TD></TR><TR><TD CLASS="quote">But does the stock crank/flywheel come balanced from the factory or not?</TD></TR></TABLE>
I would say no... but could be wrong.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by paulITR &raquo;</TD></TR><TR><TD CLASS="quote">And might I balance the Toda on the crank?</TD></TR></TABLE>
I don't think it would be needed.
Install and drive.
Old Jun 10, 2003 | 08:08 AM
paulITR's Avatar
Willard,
thanks very much for your advices.
When the work will be done I'll post a review.
Old Jun 10, 2003 | 08:31 PM
JustLooking's Avatar
Here's a couple of pics of my Toda Clutch install. Near the bottom of the pic you'll see the white mark where the flywheel and pressure plate lined up.
[http://homepage.mac.com/agentmac/019.jpg][http://homepage.mac.com/agentmac/020.jpg]
Old Jun 10, 2003 | 08:36 PM
type r 01-1063's Avatar
Default Re: Mount Toda flywheel (JustLooking)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JustLooking &raquo;</TD></TR><TR><TD CLASS="quote">Here's a couple of pics of my Toda Clutch install. Near the bottom of the pic you'll see the white mark where the flywheel and pressure plate lined up.
h8ted ek
Dec 26, 2006 05:09 PM
Mr.Integra
Nov 12, 2003 03:00 PM
wutangben
Sep 4, 2002 11:51 AM
ITR764
Dec 20, 2001 05:21 AM
