Do Camber kits squeek??
I was just wondering if camber kits squeek? I have a drop of about 2 1/4 on my car and i have ingalls front camber kit. My fronts squeek sometimes and when i lift my car to check it out I cant figure out what it is. Does anyone else have this problem???? if so how do you fix it.... It's annoying
Oh yea it mainly happens when its cold.
Modified by LSintegra619 at 7:08 AM 6/10/2003
Oh yea it mainly happens when its cold.Modified by LSintegra619 at 7:08 AM 6/10/2003
It doesnt squeek when you jack it up, ,it squeeks when i start to come to a stop. I know it isnt my breaks because it sometimes happens when im not even on my breaks. It happens most of the time in the mornin and in the evening usually when i come to a stop.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ingrate »</TD></TR><TR><TD CLASS="quote">Did you lube the poly bushings? I used white lithium grease on my progress kit and no squeaking for 2+ years..</TD></TR></TABLE>
That is your problem, your camber kit was lubed up enough
HTH
HTH
95slomocivi
Feb 23, 2006 03:48 PM
E-lude78
11
Oct 20, 2003 07:21 PM
