where and what wires are for the parking lights in a 92-95 civic
Old Jul 18, 2001 | 08:22 PM
Lei Siew Long's Avatar
Default where and what wires are for the parking lights in a 92-95 civic
i'm trying to hook up my autometer gauges and need this info. i'm thinking it is located in the steering column. any help is appreciated.
Old Jul 19, 2001 | 06:15 AM
cjb92's Avatar
Default Re: where and what wires are for the parking lights in a 92-95 civic (boostedeg6)
should be red with black stripe. located in driver side kickpanel area.
Old Jul 19, 2001 | 01:13 PM
Default Re: where and what wires are for the parking lights in a 92-95 civic (superflea)
thanks for the reply. it is much appreciated. i'll look for it tonight.
Old Jul 19, 2001 | 08:10 PM
utensil's Avatar
New User
do u just spline the wires together? how do u connect a tach if u dont have a tach on your car already? which wire do u connect it to?
Old Jul 20, 2001 | 07:34 PM
kappy's Avatar
New User
Default Re: where and what wires are for the parking lights in a 92-95 civic (utensil)
The car should be prewired for a tach. On my 97 Dx, the wire is a blue wire on the farmost left side of the cluster, there was two wires, so i spliced both, and tested out the tach with each one, and one worked (the one farthest to the left)
Old Jul 20, 2001 | 09:26 PM
utensil's Avatar
New User
Default Re: where and what wires are for the parking lights in a 92-95 civic (kappy)
i dont get it, what does splicing actually refer to? is it just when u cut the insulation from 2 wires and connect them?
Old Jul 20, 2001 | 11:49 PM
that is what i refer to it as at least. and tapping into the wire means connecting two wires without cutting either of them. this is accomplished by using a wire tapper.
Old Jul 21, 2001 | 12:30 AM
utensil's Avatar
New User
woah how do u tap into wires? and what does that do?
BTW i know nothing about anything electronic.... im trying to learn heh heh
Old Jul 25, 2001 | 09:08 PM
same here, i don't know much about electronics as well. only things that i put in that are electronic are my stereo and turbo timer. but, you tap into a wire by using these plastic things called wire tappers. you could buy it any hardware store. what you do is, put the wire that you new wire you're trying to tap on top and the wire you want to tap into on the bottom. after that, pull the plastic cover over the metal piece and squeeze them together. the metal will puncture both wires and they will be connected by the metal piece. hope this helps.
Old Jul 25, 2001 | 09:38 PM
utensil's Avatar
New User
icic, i got it! thanks boostedeg....so its like a series connection.
i learned all this stuff in physics last year, but all the terms are different haha. i guess this is more slang and the physics way is scientific
Mr.vang
Feb 14, 2008 04:33 PM
keep_up
Jul 30, 2007 11:09 AM
team2n1hatch
Apr 4, 2003 12:39 PM
nkSi
Sep 30, 2001 09:47 AM
