Using obd-2 injectors in a 89 hf
Old Jun 9, 2003 | 07:37 AM
Butch's Avatar
Default Using obd-2 injectors in a 89 hf
Swapping a b20/vtec into an 89 hf and in my previous car, I was using obd-2 rc 320cc injectors. I wanna use them in this car too and I am using the hf harness so how do I bypass the resistor box to make the newer style injectors work in this car. i am also using a harness to convert the ecu to a p28. thanks
Old Jun 9, 2003 | 08:01 AM
The Crow's Avatar
Default Re: Using obd-2 injectors in a 89 hf (Butch)
I think you can just connect the four black wires to the red wire.
Old Jun 9, 2003 | 11:59 AM
Butch's Avatar
Default Re: Using obd-2 injectors in a 89 hf (The Crow)
each factory injector has a red/blk wire and another wire that is different in color. the 4 red/blk wires go to the resistor box, and also one yellow/blk wire goes to the resistor box. If I don't use the resistor box, I need to know what to hook the 4 red/blk wires to?
Old Jun 10, 2003 | 07:23 AM
The Crow's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Butch &raquo;</TD></TR><TR><TD CLASS="quote">each factory injector has a red/blk wire and another wire that is different in color. the 4 red/blk wires go to the resistor box, and also one yellow/blk wire goes to the resistor box. If I don't use the resistor box, I need to know what to hook the 4 red/blk wires to?</TD></TR></TABLE>
Some resistor boxes have different colors. You hook them up to each other. The resistor box has one power wire going in and four going out. Cut the wire and run all five of them together, that by-passes the resistor box.
d15bfi
Sep 28, 2008 10:58 AM
laxrider
Feb 17, 2008 04:51 PM
92hybridAccord
May 6, 2005 03:35 AM
daidilus
45
Feb 9, 2005 09:18 AM
ZERO COOL
Jan 11, 2003 08:33 AM
