Zeal b6 suspension squeek, anoying!
Old Jul 18, 2001 | 07:05 PM
JDizzM's Avatar
New User
Default Zeal b6 suspension squeek, anoying!
i have had my zeal b6's for about a month now and the front aren't really bad but the back make so much squeeking noise over bumps and ruff roads.
since the back ones have the polyurethane bushings, im sure this is why i get the squeek. i just put them in without any grease or anything. should i take them out and put grease on the bushing or is there a spray i could use?
please help! thanks.
Old Jul 18, 2001 | 07:29 PM
Todd00's Avatar
I said I don't want a title!
Default Re: Zeal b6 suspension squeek, anoying! (JDizzM)
Yep, welcome to metal-to-metal pillowball mounts. The front ones squeak as well, but you just can't hear them since they are under the hood.
You could grease the top hat, but I don't think it would do a ton of good. However, you could cut a thin rubber gasket for the top and put that in between the suspension and body if you were really ambitious.
Old Jul 18, 2001 | 09:34 PM
Warren's Avatar
Wrong-Way Wang
Default Re: Zeal b6 suspension squeek, anoying! (Todd00)
I don't get the whole pillowball mount thing. The stock shock bushings are mostly metal, and they really don't compress, so they let the shock work immediately. What parts are the pillowball mounts replacing? I thought it was basically just the top shock bushings and hat.
I had a machine shop drill out my stock bushings so that I could use them with my Truechoice coilovers. Better than polyurethane bushings.
Warren
Old Jul 18, 2001 | 09:59 PM
Todd00's Avatar
Default Re: Zeal b6 suspension squeek, anoying! (Warren)
The Zeal shockbody/tophats, etc are kindof one piece. All bushings are poly with metal inserts.
[Modified by Todd00, 11:00 PM 7/18/2001]
Old Jul 19, 2001 | 11:07 PM
JDizzM's Avatar
New User
so todd00 do you just take the squeeking as a part of improved performance or have you done anything personal to tone it down? thanks i might try the rubber gasket thing on top.
Old Jul 20, 2001 | 03:02 AM
spoonek4's Avatar
U can contact Ben at info@aj-racing.com I think he can help u out on that.
U got the coilovers from him or?
Old Jul 20, 2001 | 03:07 AM
COREY ITR#625's Avatar
Default Re: Zeal b6 suspension squeek, anoying! (spoonek4)
My Apex N-1's have been squecking for about 3 weeks and I don't have pillow mounts. Any ideas?
Old Jul 20, 2001 | 05:42 AM
Kengs's Avatar
Default Re: Zeal b6 suspension squeek, anoying! (COREY ITR#625)
My Zeal Function S squeak a bit in the back, but I'm hoping the Cusco lower tie bars I picked up this time will help reduce it a bit.
Regardless, I think the improvement in damping performance is an acceptable tradeoff for the squeaking.
Old Jul 20, 2001 | 07:03 AM
ITRinEJ1's Avatar
Default Re: Zeal b6 suspension squeek, anoying! (kengs)
my main man kengs!!!
having fun in china/japan??
when u coming back
Old Jul 20, 2001 | 11:38 AM
Todd00's Avatar
You could always grease the crap out of everything--that should tone things down a bit. I deal with the minor squeaking as most do with the volume of a performance exhaust. There is some give and take when it comes to hi-performance parts
Konigretracts
Nov 22, 2012 05:05 PM
nicanbeastfool
Suspension & Brakes
May 12, 2010 03:22 PM
madracer
Suspension & Brakes
10
Oct 25, 2008 02:29 PM
ednyboo
Dec 7, 2007 04:00 PM
Mr.E.G.
Welding / Fabrication
10
Jul 6, 2006 05:10 PM
