Please someone explain compression to me!!!!!!
Old Jun 8, 2003 | 05:55 PM
Rhythm Racer's Avatar
Default Please someone explain compression to me!!!!!!
I need help im totally ignorant to the subject of compresion ratios.....someone told me i should run 11:1 to hit mid 14s in my SOHC VTEC ( ofcourse with other work but anyways how do i change compression ratios what does it do how does it work infrom me please!!!!!!!!!!
Old Jun 8, 2003 | 06:09 PM
Si Arn's Avatar
Default Re: Please someone explain compression to me!!!!!! (Rhythm Racer)
well I know if compression in one cylinder is lower than all the rest something is wrong.
-Captain Obvious.
Old Jun 8, 2003 | 06:13 PM
ciRcuitJerk's Avatar
jus f0 dekarayshunZ
Default Re: Please someone explain compression to me!!!!!! (Si Arn)
higher comp pistons....thinner head gasket...go to the search button and type in compression
Old Jun 8, 2003 | 08:06 PM
NonovUrbizniz's Avatar
Loved
simply put it's the ratio of difference between the volume of the cylinder with the piston at tdc and bdc.
Old Jun 8, 2003 | 08:48 PM
Dan GSR's Avatar
11:1 ratio
think like this....take 11 gallons of air...and stuff it into a 1 gallon bottle
thats what compression does....makes more potential energy
Old Jun 8, 2003 | 10:05 PM
SpoonFedHatch's Avatar
for some n00b friendly explanations
Old Jun 8, 2003 | 10:17 PM
Chris y0!'s Avatar
Default Re: Please someone explain compression to me!!!!!! (Dan GSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dan GSR &raquo;</TD></TR><TR><TD CLASS="quote">11:1 ratio
thats what compression does....makes more potential energy</TD></TR></TABLE>
right. if you have 11 "gallons" of air and fuel inside your combustion chamber, it will obviously produce more horsepower than only 9 gallons.
Old Jun 9, 2003 | 07:24 AM
Default Re: Please someone explain compression to me!!!!!! (Chris y0!)
Thanks guys . now how do i make it 11 instead of what it is stock.do i need to do any internal work like pistons and rods valve springs when i turn up the ratio!!!!!again thanks!!
Old Jun 9, 2003 | 09:00 AM
Chris y0!'s Avatar
you would need pistons to go up to 11.
Old Jun 9, 2003 | 09:06 AM
ahobbs's Avatar
HELLO,GOOD MORNIN'
https://honda-tech.com/zerothread?id=386525
This is what you have been asking for. I had this question several moths ago, I went and found it for you. It breaks it down completely and lets you know how comression works.
Old Jun 9, 2003 | 09:10 AM
Dark Halo's Avatar
- I like how you put that. Good topic by the way.
Old Jun 9, 2003 | 09:45 AM
mixmastabob's Avatar
Default Re: Please someone explain compression to me!!!!!! (Dark Halo)
since we are asking questions, how do you know what octane to run at what ratio?
EDIT: and what would you use to test the ratios?
Old Jun 9, 2003 | 09:47 AM
Chris y0!'s Avatar
Default Re: Please someone explain compression to me!!!!!! (mixmastabob)
i would run premium on anything over 10:1, and race gas on anything over 13:1
Old Jun 9, 2003 | 09:50 AM
allmtr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris y0! &raquo;</TD></TR><TR><TD CLASS="quote">i would run premium on anything over 10:1, and race gas on anything over 13:1</TD></TR></TABLE>
yeah. i run 12:1 and im ok on 91. just be sure to tune it
EastSideRacer
K Series
Mar 24, 2010 06:49 PM
Combustion Contraption
53
Nov 18, 2006 09:50 PM
7speed
Sep 13, 2005 07:39 AM
1.8T_EG
Jul 6, 2004 08:27 AM
stupidfast
Oct 20, 2002 03:50 PM
