Please someone explain compression to me!!!!!!
I need help im totally ignorant to the subject of compresion ratios.....someone told me i should run 11:1 to hit mid 14s in my SOHC VTEC ( ofcourse with other work but anyways how do i change compression ratios what does it do how does it work infrom me please!!!!!!!!!!
Re: Please someone explain compression to me!!!!!! (Rhythm Racer)
well I know if compression in one cylinder is lower than all the rest something is wrong.
-Captain Obvious.
-Captain Obvious.
jus f0 dekarayshunZ
Re: Please someone explain compression to me!!!!!! (Si Arn)
higher comp pistons....thinner head gasket...go to the search button and type in compression
11:1 ratio
think like this....take 11 gallons of air...and stuff it into a 1 gallon bottle
thats what compression does....makes more potential energy
Re: Please someone explain compression to me!!!!!! (Dan GSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dan GSR »</TD></TR><TR><TD CLASS="quote">11:1 ratio
thats what compression does....makes more potential energy</TD></TR></TABLE>
right. if you have 11 "gallons" of air and fuel inside your combustion chamber, it will obviously produce more horsepower than only 9 gallons.
Re: Please someone explain compression to me!!!!!! (Chris y0!)
Thanks guys . now how do i make it 11 instead of what it is stock.do i need to do any internal work like pistons and rods valve springs when i turn up the ratio!!!!!again thanks!!
HELLO,GOOD MORNIN'
https://honda-tech.com/zerothread?id=386525
This is what you have been asking for. I had this question several moths ago, I went and found it for you. It breaks it down completely and lets you know how comression works.
- I like how you put that. Good topic by the way.
Re: Please someone explain compression to me!!!!!! (Dark Halo)
since we are asking questions, how do you know what octane to run at what ratio?
EDIT: and what would you use to test the ratios?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris y0! »</TD></TR><TR><TD CLASS="quote">i would run premium on anything over 10:1, and race gas on anything over 13:1</TD></TR></TABLE>
yeah. i run 12:1 and im ok on 91. just be sure to tune it
