filling in the molding holes
Old Jun 8, 2003 | 05:45 PM
ghettols's Avatar
Default filling in the molding holes
my buddy is getting a paint job soon and wants to fill in those holes when you take off the moldings(btw, he has a 95 eg)...what did some of you guys do to fill it in(bondo?)?
Old Jun 8, 2003 | 08:51 PM
slvrcivic97's Avatar
Default Re: filling in the molding holes (ghettols)
Put sheet metal behind the door so that it is against the hole on the inside. Then put layers of bondo on the hole (that's now covered up from the inside with sheet metal) until the bondo is a little higher than the rest of the molding. Sand down till even. Wala. You should not use all bondo when shaving the moldings though, but in your case, or his case, using bondo for the little hole is aOK IMO. Hope this helps a little.
Old Jun 8, 2003 | 09:18 PM
ghettols's Avatar
Default Re: filling in the molding holes (slvrcivic97)
thanx
Old Jun 9, 2003 | 12:04 AM
dirtyazn's Avatar
weld the holes plz
your friend will regret using bondo when it cracks out later on
these are pretty big rectangular holes not small wing holes
Old Jun 9, 2003 | 03:35 AM
B Speed's Avatar
Default Re: filling in the molding holes (dirtyazn)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dirtyazn &raquo;</TD></TR><TR><TD CLASS="quote">weld the holes plz
Welding is def the best plan.
Old Jun 9, 2003 | 06:42 AM
Default Re: filling in the molding holes (B Speed)
Yeah, now that I think about it, weld them. Just be sure not to warp the door.
Old Jun 9, 2003 | 08:54 AM
2lowintegra's Avatar
weld
Old Jun 9, 2003 | 11:02 AM
eh3 93's Avatar
Default Re: filling in the molding holes (2lowintegra)
yea I had mine welded.
Old Jun 9, 2003 | 01:54 PM
cre18's Avatar
Default Re: filling in the molding holes (eh3 93)
great job!
italianchooch88
Paint and Body
42
Aug 30, 2009 10:18 PM
Jlamar757
Jul 6, 2009 09:12 AM
WangstaCivic
Paint and Body
26
Apr 30, 2008 09:08 AM
N7J3H2C
Paint and Body
Jul 25, 2007 05:04 AM
