PICS Buddyclub RS damper fitted..
Old Jun 8, 2003 | 05:21 PM
DC5-R's Avatar
Default PICS Buddyclub RS damper fitted..
hi guys here are some quick pics i took of the car...sorry quality isn't that good as i was in a rush...
the Cwest 4 point adj GT wing is there for TRACK use and rarely used for street...
cheers
Old Jun 8, 2003 | 06:08 PM
rsx-lake's Avatar
Default Re: PICS Buddyclub RS damper fitted.. (DC5-R)
ummm...look nice!!!!
Old Jun 8, 2003 | 06:59 PM
Team's Avatar
Default Re: PICS Buddyclub RS damper fitted.. (rsx-lake)
dang man very nice Australia looks better than I imagined
Old Jun 8, 2003 | 07:08 PM
Todd00's Avatar
I said I don't want a title!
Did you have any problems with running out of adjustment on the tierods? More camber + lower car = no more toe adjustment (usually). Just wondering if the BCs have any provisions for this.
Old Jun 8, 2003 | 07:10 PM
bus stop's Avatar
NICE
by any chance you have pic w/o the wing. I always wonder how the trunk looks like once the GT wing is off the car.
Old Jun 8, 2003 | 07:33 PM
DC5-R's Avatar
Default Re: PICS Buddyclub RS damper fitted.. (Todd00)
as for the tie rod settings at that height no, there is still room for adjustment...
what i had problems with though is that not any suspension shop could do this kind of tuning...so race suspensions specialists were up to the task...
i just like to thank ALAN for AJ POWER canada for helping me out with the technical details..
WHOITR- no i haven't have pics without wing as I put on the stock DC5R wing when im done with the GT wing...but i will take it off sometime today and take a pic for you...
cheers
Old Jun 8, 2003 | 07:51 PM
choppystyx's Avatar
how does it ride?? and how is the adjustment on it as in stiffness for street and race???
Old Jun 8, 2003 | 08:11 PM
DC5-R's Avatar
Default Re: PICS Buddyclub RS damper fitted.. (choppystyx)
honestly i believe this coilover system emphasises more on circuit usage than street applications. Although i do use these coilovers on the street it is still pretty bumpy ride...but the performance they give far outweighs the bumpy ride....
Old Jun 8, 2003 | 08:12 PM
FrostyDC4's Avatar
"Haters Gonna Hate"
25 Year Member
Nice
Old Jun 8, 2003 | 08:28 PM
bus stop's Avatar
Thanks for your help
btw....what is the spring rate coming with your Buddyclub? I want to know will they have different spring rate for the type-R vs the type-S.
Old Jun 8, 2003 | 09:47 PM
DC5RK20A's Avatar
Default Re: PICS Buddyclub RS damper fitted.. (WhosITR)
The BC racing spec should be 10kg-mm front and 16kg-mm rear. Not sure if the Aussie R is the same as the Japan R, but the stock spring rates are progressive from 3.2 - 5 kg-mm front and 5.6 - 8 kg-mm rear. The stock suspension on mine feels as if it is already an aftermarket piece, I like it!!! If and when I get a suspension, I was going to look at the Buddy Club Racing Spec but possibly change the springs with some Swift springs, something in the neighborhood of 16 and 30 front and rear.
Chris
Old Jun 8, 2003 | 11:04 PM
DC5-R's Avatar
Default Re: PICS Buddyclub RS damper fitted.. (DC5RK20A)
yes they come with F10kg/mm and R16kg/mm....although they can take more aggressive spring rates...46mm piston and 15 way adjustable...
yes swift springs are the go for me as well....also due to there lightweight design...
just a couple more pics:
Modified by DC5-R at 8:25 AM 6/9/2003
Old Jun 8, 2003 | 11:46 PM
DC5-R's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DC5RK20A &raquo;</TD></TR><TR><TD CLASS="quote">The BC racing spec should be 10kg-mm front and 16kg-mm rear. Not sure if the Aussie R is the same as the Japan R, but the stock spring rates are progressive from 3.2 - 5 kg-mm front and 5.6 - 8 kg-mm rear. The stock suspension on mine feels as if it is already an aftermarket piece, I like it!!! If and when I get a suspension, I was going to look at the Buddy Club Racing Spec but possibly change the springs with some Swift springs, something in the neighborhood of 16 and 30 front and rear.
Chris</TD></TR></TABLE>
I have a feeling the stock JDM DC5R sussy would feel like my stock/spoon spring setup... F7.2 kg/mm R8.4 kg/mm - this felt good for street, it really eliminated alot of that nasty bodyroll
Im still playing around with the settings but I am finally happy with the height settings on my car.
Old Jun 8, 2003 | 11:51 PM
DC5-R's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WhosITR &raquo;</TD></TR><TR><TD CLASS="quote">Thanks for your help
BC RS have only one type - which is for DC5 (both Type S and R).
Old Jun 9, 2003 | 06:04 AM
Todd00's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DC5-R &raquo;</TD></TR><TR><TD CLASS="quote">as for the tie rod settings at that height no, there is still room for adjustment...
What about the angle of the tierods? Do you still have that \_/ shape? I'm wondering if BC modifys their tierod/strut attachment to compensate for the tierod issues.
Old Jun 9, 2003 | 11:18 AM
Spikey's Avatar
both the Buddy Club Racing Spec Dampers and the Zeal V6 adjust the tie rod a bit higher for better clearance
wish i had a picture that showed it
Old Jun 9, 2003 | 12:39 PM
DC5-R's Avatar
I will take a pic for you..and spikey is right ...because i know the bilstein setup need to attach washers above the slipjoint...and so or other coilover systems....
Old Jun 9, 2003 | 12:41 PM
JUN JDM's Avatar
Looks clean.......but i think it would look better wingless.........my opinion
Old Jun 9, 2003 | 02:27 PM
DC5RK20A's Avatar
Nice pics! Is that the height setting you are happy with now? To me it looks perfect, not too low.
Chris
Old Jun 9, 2003 | 05:53 PM
sjracer's Avatar
How about a picture out of the grass so we can get a good perspective of the ride height. Maybe you could take one on a level flat surface for us. Thanks
PS: Looks good so far.
Old Jun 9, 2003 | 10:16 PM
PurplePill's Avatar
*jaw drops*
Old Jun 9, 2003 | 11:49 PM
DC5-R's Avatar
Yes I am happy with this height setting....it took alot of fiddling to get it right As for a photo on an my driveway or something I'll try to get one soon as im quite busy atm.
Old Jun 10, 2003 | 09:10 AM
SlammedBlueEM2's Avatar
Wish I could park on my front lawn.
Old Jun 10, 2003 | 10:35 AM
Todd00's Avatar
Default Re: PICS Buddyclub RS damper fitted.. (Spikey)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Spikey &raquo;</TD></TR><TR><TD CLASS="quote">
wish i had a picture that showed it</TD></TR></TABLE>
Yeah, me too. I'm not sure what you mean by "higher". The tie-rod attachment would need to be further out and lower toward the ground to get rid of the out-of-adjustment issue and the 'V' problem.
Old Jun 10, 2003 | 03:56 PM
wangan's Avatar
I know AJ Racing is the best shop in Canada.
How long did it took before they shipped to you your BUddy Club.
