ITR cams on GSR stock valve train.....how high to rev?
Old Jun 8, 2003 | 05:09 PM
Petah's Avatar
Default ITR cams on GSR stock valve train.....how high to rev?
I have a set of ITR cams in my GSR engine and i am running a JDM ITR ECU which has rev limit set at 8500rpm (i think 9000 rpm) on the tach seeing it's off at those engine speeds. The stock GSR has a rev limit of 8000. I want to know what is the highest people have reved to SAFELY with a similar setup? I have gone as high as 8300rpm (tach indicated) thus far but i want to know how much further i can push with the stock valve train. Thanks!
Old Jun 8, 2003 | 05:29 PM
youngvedder's Avatar
Default Re: ITR cams on GSR stock valve train.....how high to rev? (eg-six)
I wouldnt go any further. I think the GSR rev limit is 8200, and that is probably pushing it.
yv
Old Jun 8, 2003 | 05:59 PM
beevo.'s Avatar
Like youngvedder said I wouldn't go past 8200rpm until you upgrade the valvesprings to atleast ITR.
Old Jun 8, 2003 | 06:05 PM
acatak's Avatar
Default Re: (GoldenDC2)
... I would even shift at 8100 until you upgrade those valve springs
Old Jun 8, 2003 | 08:47 PM
Sukebei Oni's Avatar
Default Re: (acatak)
i have ITR cams with a my stock GSR valvetrain. i only rev it to the stock GSR Redline, but i wouldn't want to go any higher than the stock GSR limit. i did hit the limiter one time cause i forgot that i had put in a ITR gauge cluster and i was thinking i was going to shift at the ITR redline but there was no damage done, since it still was limited by the stock GSR ECU.
Old Jun 9, 2003 | 12:56 AM
AllmotorJunkie's Avatar
dyno your car and see if you still make power past 8000 rpm. If yes, then consider upgrading valvetrain. If not, stay with stock settings.
Old Jun 9, 2003 | 08:37 AM
INTEGRAMIKE's Avatar
Default Re: ITR cams on GSR stock valve train.....how high to rev? (AllmotorJunkie)
i have the itr cams with the itr inner springs on the intake and the gsr inners on the exhaust. I was under the impression this is the same as the itr. I have only taken it to 8100. Should I be able to take it much higher?
Old Jun 9, 2003 | 08:47 AM
P1mpSlap's Avatar
I wonder if my tach is off. I have a JDM ITR cluster and I constantly take it to the very 1st marking of the redline. 8400 RPM.
Last time I dynoed the guy took it to the redline on my ITR cluster and blipped it of the revlimiter. He only said it was 300rpms off.
Old Jun 9, 2003 | 09:16 AM
SiR-DC2's Avatar
Default Re: (P1mpSlap)
w/ stock internals and just bolt ons w/ my CTR cams mine made peak power untuned at about 7800 rpms (this is where power felt like it was rolling off) so I'd shift mine at 8000 or 8200 rpm and now higher. I had chipped my P72 and set my redline w/ an MSD 6AL
Old Jun 9, 2003 | 09:35 AM
1hotintegra's Avatar
stock
Old Jun 9, 2003 | 11:11 AM
Slain's Avatar
i wouldnt take it over the stock redline till you upgraded your valvetrain... last thing you need is valvetrain piece to let go
Old Jun 9, 2003 | 11:20 AM
patdemps's Avatar
Default Re: (Slain)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Slain &raquo;</TD></TR><TR><TD CLASS="quote">i wouldnt take it over the stock redline till you upgraded your valvetrain... last thing you need is valvetrain piece to let go </TD></TR></TABLE>
...Just ask yourself if its worth replacing parts. If it is then you have mad cash and should be hit with a . If not then dyno the car and find out for sure. Id be safe and take it to GSR redline. Don't do something your going to regret
Old Jun 9, 2003 | 03:46 PM
alexboy's Avatar
Default Re: (patdemps)
if you had a Skunk 2 Intake Manifold and an itr ecu you could rev to 8400 with no probs
Old Jun 9, 2003 | 03:48 PM
threatcon13's Avatar
New User
Default Re: (alexboy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alexboy &raquo;</TD></TR><TR><TD CLASS="quote">if you had a Skunk 2 Intake Manifold and an itr ecu you could rev to 8400 with no probs</TD></TR></TABLE> Whats the IM have to do with how high he can rev safely?
Old Jun 9, 2003 | 04:00 PM
alexboy's Avatar
Default Re: (Threatcon13)
it doesn't, the manifold is needed because and itr ecu won't open the butterflies valve in the gsr manifold
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Threatcon13 &raquo;</TD></TR><TR><TD CLASS="quote"> Whats the IM have to do with how high he can rev safely? </TD></TR></TABLE>
Old Jun 9, 2003 | 06:51 PM
b18cu's Avatar
i'd rev the **** out of it!
Old Jun 10, 2003 | 03:29 AM
Xsi's Avatar
Xsi
I've been revving to the revlimit of my B16 with CTR cams with no problems, wouldn't go over though
Old Jun 17, 2003 | 11:11 PM
hndarcrb18c1's Avatar
Default Re: (Xsi)
&lt;--- Jun's with stock 01 gsr valve train 8500Rpm's alls day long under NOS I have 40,xxxx miles.... Keeps on ticking...Tho it does mske me cringe one in a while...LOLOLOL
Old Jun 18, 2003 | 01:07 AM
92lsr's Avatar
Default Re: (hndarcrb18c1)
i just got a p28 ecu chipped to 8500, i still only have took it up to 8200-8300 a few times i will get the valvetrain done someday
Old Jun 18, 2003 | 04:08 AM
BluFire's Avatar
I have the S2 manifold and Hondata and Ive hit 9000 a few times on ITR Valve Train..
Link16
Apr 18, 2008 05:20 AM
A2_8U
Dec 12, 2006 11:48 AM
1.8T_EG
Aug 19, 2003 05:58 PM
bhcvc
Mar 19, 2002 09:17 PM
jabroni95gsr
Oct 22, 2001 12:07 PM
