Skunk2 IM on GSR..the thingy for cable is too long
ok..the plate that holes the throttle cable is in the way of my frnot upper strut bar. is there anyway i can solve that problem? do i have to get like itr one to clear it?
Jeff-
Jeff-
You need an ITR throttle cable bracket or cut and drill new holes in the one you are using now. Thats what I did and I never had a problem with it.
I used my stock GS-R parts and it works perfectly fine. Here's how it looks tho:
*Don't mind the grounding cables. They've been fixed.*
Type r throttle body, type r throttle cable bracket, type r throttle cable - presto! Problem is solved ...
Well, at least that's how I did it. Besides, you'll want a larger throttle body with the S2 IM anyways.
JLi
JLi
Eghatchgsr8
Oct 11, 2014 03:09 PM
fred92htch
Apr 7, 2003 07:55 PM
