Subframe Question
Old Jun 8, 2003 | 08:27 AM
The G2 Racer's Avatar
Default Subframe Question
When you install a rear lower tie bar you replace the sub frame bolts with longer ones that come with the bar. I no longer have the stock bolts but need to know the size of the stock bolts so I can go pick up a pair.
So what's the size of the stock 92-95 Civic rear subframe bolts?
Thanks.
Old Jun 8, 2003 | 08:35 AM
NNHC's Avatar
Default Re: Subframe Question (The G2 Racer)
A few dollars then you can pick some up from the dealer. I know you can match some out there but I always get those from the dealer to save my hassle.
Old Jun 9, 2003 | 08:08 AM
PupaScoopa's Avatar
Default Re: Subframe Question (NNHC)
Look in your phonebook for a nut/bolt place. Take your short bolt so they can match the threads and grade. You'll definitely pay less.
Old Jun 9, 2003 | 09:40 AM
B16b2b's Avatar
Default Re: Subframe Question (PupaScoopa)
make sure you get something, if not honda, just as strong as a honda bolt. grade 10 i think for those....
HotCheetos
10
Dec 11, 2010 09:07 PM
so simple
Suspension & Brakes
Jul 1, 2008 05:22 PM
supracrx
Suspension & Brakes
Dec 7, 2007 07:39 AM
ninety-five_DB
Suspension & Brakes
11
Aug 27, 2006 07:16 AM
Greasemonkey
Sep 7, 2003 11:26 PM
