Can a turbo timer clear out nitrous from system?
Old Jul 18, 2001 | 12:00 PM
myNAteq's Avatar
New User
Default Can a turbo timer clear out nitrous from system?
Someone told me that. Is it true and how?
Old Jul 18, 2001 | 08:14 PM
boomslang's Avatar
Default Re: Can a turbo timer clear out nitrous from system? (myNAteq)
A turbo timer just lets the car idle for a set amount of time after the key has been pulled from the ignition. It lets the turbo cool down while you go about your business.
"Clear out nitrous from the system" sounds like rice boy gibberish. It doens't make sense.
Old Jul 19, 2001 | 03:03 PM
ringgold's Avatar
Default Re: Can a turbo timer clear out nitrous from system? (Teken)
Why would you need a turbo timer to clear out nitrous? I guess he thinks nitrous just lingers around after you spray it.
Old Jul 19, 2001 | 03:55 PM
MugenFormula1's Avatar
Default Re: Can a turbo timer clear out nitrous from system? (ringgold)
try a flowbee
Old Jul 19, 2001 | 05:07 PM
earl's Avatar
As soon as you shut off the nitrous boost there in no nitrous left in the system unless you count what nitrous is left in your nitrous bottle....Can any scholars on this board use the word nitrous more than four times in one sentence?
Old Jul 19, 2001 | 09:44 PM
accordking's Avatar
Default Re: Can a turbo timer clear out nitrous from system? (earl)
lol....nos.nos,nos,nos, and more nos!!
Old Jul 20, 2001 | 06:04 AM
Racing rice's Avatar
New User
Default Re: Can a turbo timer clear out nitrous from system? (accordking)
n2o is a gas.. when its used it just gets burned off... I have no idea why anyone would tell you it stays in the system.
Old Jul 20, 2001 | 12:13 PM
eviladam's Avatar
if you do get nitrous, make sure not to wire your nitrous heater to constant +12V or your nitrous heater will heat the nitrous enough that the nitrous will expand and the nitrous bottle will explode just like that one guy who blew up his garage when the nitrous in his trunk went kablammo. I counted 7 in one sentence. And yes, turbo timers will clear your system, as well as healing small cuts and abrasions, removing unsightly back hair and increase your sex appeal.
Old Jul 20, 2001 | 12:55 PM
Redlinin fo EVA's Avatar
New User
no it cannot. turbo timer is for turbo. but i think he was thinking about a nitrous purge system which clears the leftover nitrous gunk out of your lines so you have a fresh clean shot of it the next time you use the nitrous...
Old Jul 20, 2001 | 09:01 PM
BoM's Avatar
BoM
Default Re: Can a turbo timer clear out nitrous from system? (Redlinin fo EVA)
damn ricers
Old Jul 25, 2001 | 03:14 PM
EVOCELICA's Avatar
New User
Default Re: Can a turbo timer clear out nitrous from system? (eviladam)
If your nitrous bottle gets to hot it has a blow out valve that will break and releave the pressure from the bottle, it will not just blow up. Who ever told you that you need a turbo timer to clear nitrous is a moron they should be smack upside the head for saying something so stupid.
guessohw
Jan 12, 2009 07:39 AM
4doorcivic16
Aug 22, 2006 08:25 PM
Legendaryyaj
Nov 18, 2003 02:26 PM
mattduskater
Oct 4, 2003 06:59 PM
