what would be faster out of these 2 setups?
b18c1 with ctr pistons, ctr cams, and possibly a golden eagle intake manifold...the pistons would bump compression up to 12.0
or
b18c5 stock....
in a ek hatch..i'm trying to decide on setups..thanks
or
b18c5 stock....
if you must chose one out of those 2, I would go for GSR.
But for a heavy EK, H22 sounds better to me. especially n/a.
Jay Kim
Jay Kim
If you change the stock manifold to say a Skunk2.The first one for sure as long as it's built/tuned correctly.I personally think the b18c5/R is overrated.The tranny will also play a critical part.
i'd go with the gsr and instead of golden eagle go with skank2, yes skank2 manifold. no matter which setup you go with suspension/weight/gearing ratio and most importantly experience of the driver...you can have a jun/spoon built motor and no experience and cant break into 13's with less than 200whp.
keep in mind bigger is never better.
Modified by eg6si at 2:24 AM 6/8/2003
personally if they were the same amount of $ then i would get the R motor. the only differences in power adders seem to be the 1.5 or so bump in cr and slightly more duration on the cams. there wouldnt be a huge difference in power between these 2 setups and personally id rather have the r motor. its a better platform to build from, the crank is better, the rods are better, valve train is better, lighter valves, better exhaust and intake springs. the r blocks are also all assembeled by hand to ensure build quality. basically your lookin at maybe 10hp difference maybe? now there are people out there that are making 200 whp on stock b18c5 blocks...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JCushing »</TD></TR><TR><TD CLASS="quote">the valves are lighter but the same size. retainers are the same though</TD></TR></TABLE>
ah ok. thanks for clearing that one up for me
ok well what are the prices gonna be? i would tell ya to take the R motor but if its 1k more than the gsr i would tell ya to take the gsr
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JCushing »</TD></TR><TR><TD CLASS="quote">ok well what are the prices gonna be? i would tell ya to take the R motor but if its 1k more than the gsr i would tell ya to take the gsr</TD></TR></TABLE>
how would you make a gsr faster than a type r for 1k dollars (n/a)...just curious to see what you'd say....?
coreysef
27
Feb 12, 2012 09:13 PM
redlseg
Apr 3, 2005 12:31 PM
GQ 05YellowEVO8
Apr 24, 2003 08:52 AM
