mini-me questions?
Old Jun 7, 2003 | 06:32 PM
90da4dr's Avatar
Loved
Default mini-me questions?
I have been reading just about every post that i can find. It seems like there is not to much info on the 1.5 mini-me's. So I have just a couple of questions.
From people with experience with the 1.5 mini-me
1) with the y8 or z6 head, what cam would i be able to use without worrying about clearance issues.
2) who has ran a chipped pr3, p28, chipped pm6 or pm6 with vtec controller, or zdyne one wire conversion on a sohc vtec? Which runs better?
3) If I do an obd-1 conversion do i still need the injector resistor box?
i have an 89 civ hb dx
Modified by 89civ at 11:19 PM 6/7/2003
Old Jun 8, 2003 | 12:57 AM
AbaZ's Avatar
Default Re: mini-me questions? (89civ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 89civ &raquo;</TD></TR><TR><TD CLASS="quote">I have been reading just about every post that i can find. It seems like there is not to much info on the 1.5 mini-me's. So I have just a couple of questions.
Modified by 89civ at 11:19 PM 6/7/2003</TD></TR></TABLE>
1. What aftermarket cam? The compression isnt raised that high, and I would assume all aftermarket and stock cams will be just fine. (unless this was going on a 8valve D15)
2. I have ran a few different setups, 1 wire zdyne works the best... also have done a PM6 w/ a VAFC.. works just fine if you tune it on a dyno w/ wideband o2 support.
3. A injector resistor box depends on what type of injectors you use, most all obd1 injectors are saturated, so no, you wouldnt need the resistor box. 88-91 si injectors are hold & peak and will need a resistor.
Jeff
Arthas
24
Sep 26, 2010 11:08 AM
bowdown201
Oct 5, 2007 02:51 PM
scorpion_86403
Aug 30, 2007 11:01 AM
young noob
Dec 15, 2005 08:33 AM
Skinflute22
Aug 9, 2005 12:29 PM
