b16 or b18 into 88-91 hatch????
Old Jun 7, 2003 | 01:33 PM
durrett syndrome's Avatar
Default b16 or b18 into 88-91 hatch????
ok i have a 88-91 hatch. im on a pretty tight budget. i know if i get a b16 its faster then a ls stock. but if i decide to get an ls i wanan get the better one. not the b18a but the b18b. i heard the b18b is better performance wise. then later on down the road i was going to turbo the ls. so is that the right ls to get and what wiring modifications will i need. thanks a lot
Old Jun 7, 2003 | 03:57 PM
silverCRXTC's Avatar
Default Re: b16 or b18 into 88-91 hatch???? (durrett syndrome)
if your hard for cash go ls, u can get a ls for 750 and swaped for under 1500
b16a will cost u more (1250+) but if u can buy a g2 teg (crashed) for like 800 and swap everything over and even do a brake upgrade, you'll be sitting phat for litttle cash
Old Jun 7, 2003 | 04:29 PM
Default Re: b16 or b18 into 88-91 hatch???? (silverCRXTC)
so it would be best to get the 90-93 ls motor? isnt the 94+ ls motor the best one???
Old Jun 8, 2003 | 09:27 AM
ttt
Old Jun 8, 2003 | 09:51 AM
ridestrt's Avatar
The 92-93 LS motors are rated at 10 more HP then the 90-91 but this is because they are OBD-1. No matter what, it is easier to run a non-OBD motor in an EF. They do make a conversion harness if you really need that 10 extra HP. The B18B motors have a little bigger cams and a little more compression. Just get a B18A unless you can find a B18B for cheap.
Old Jun 8, 2003 | 10:24 AM
STHPERFORMANCE's Avatar
Default Re: (NMcivicEF)
I choose the b18b1 in my 91 si....... It has the power down in the RPM of daily driving.... b16 motors you gotta rev the **** out of them to make any kinda power. Also those b16a arent very torquey...
Get a LS with a GSR tranny, you'll love every moment, i know i do
Old Jun 8, 2003 | 12:33 PM
Default Re: (Outkast)
how was the swap Outkast??
how was the swap. isnt that motor obd-1 so didnt u need a different harness? also was ur tranny hydro or cable? thanks a lot
Old Jun 8, 2003 | 05:53 PM
Default Re: (durrett syndrome)
back to the top.....
Old Jun 8, 2003 | 08:28 PM
This is the stuff i used.................
Mount Kit - Place Racing 3 mount kit
Shift Linkage - Hasport
Motor- 2001 Integra LS
Tranny - 1992 GSr cable trans
basicly i used my stock 91 si wire harness , had to swap crank pulleys cause the 2001 was larger and hit the radious rod.
let me know if u need any other info....
Old Jun 9, 2003 | 06:24 AM
oh iight thanks that answered alot
Old Jun 9, 2003 | 08:55 AM
Mr Furball's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by durrett syndrome &raquo;</TD></TR><TR><TD CLASS="quote">not the b18a but the b18b. </TD></TR></TABLE>
I think this is a CTR motor not LS. (b18B)
Old Jun 9, 2003 | 09:09 AM
itzxeo's Avatar
Default Re: b16 or b18 into 88-91 hatch???? (FURBALL B-16)
No!
B16b = Civic type R
b18a = LS
b18b = ls
b18c1 = GSR
b18c5 = Integra type r
Old Jun 9, 2003 | 09:42 AM
Mr Furball's Avatar
Default Re: b16 or b18 into 88-91 hatch???? (itzxeo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itzxeo &raquo;</TD></TR><TR><TD CLASS="quote">
b18a = LS
b18b = ls
What's the difference
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itzxeo &raquo;</TD></TR><TR><TD CLASS="quote">No!
I don't think this was necessary, I said " I think"
Old Jun 9, 2003 | 09:45 AM
raene's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FURBALL B-16 &raquo;</TD></TR><TR><TD CLASS="quote">
What's the difference</TD></TR></TABLE>
Year of the motor. B18A = '90-'93, B18B = '94+.
Old Jun 9, 2003 | 03:01 PM
Default Re: b16 or b18 into 88-91 hatch???? (raene)
ttt
Old Jun 9, 2003 | 06:43 PM
goforbroke's Avatar
MEAT PATTY
just read my sig
Old Jun 10, 2003 | 07:48 AM
thevtecnician's Avatar
Default Re: b16 or b18 into 88-91 hatch???? (goforbroke)
install wise, if your never going to upgrade the motor, get the b16. a b16 will pull harder than a ls when both stock. but the ls has more potential, but will be less reliable. Building a b16 is effective because it alreayd has vtec, so you dont to convert to vtec. Tmany peoples ls/vtec conversions are shawddy, but never theless, they both cost about the same. and b16 motors arent very torquey, but ls motors arent very horsepowery, hahahaha
Old Jun 10, 2003 | 07:58 AM
Default Re: b16 or b18 into 88-91 hatch???? (thevtecnician)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thevtecnician &raquo;</TD></TR><TR><TD CLASS="quote">install wise, if your never going to upgrade the motor, get the b16. a b16 will pull harder than a ls when both stock. but the ls has more potential, but will be less reliable. Building a b16 is effective because it alreayd has vtec, so you dont to convert to vtec. Tmany peoples ls/vtec conversions are shawddy, but never theless, they both cost about the same. and b16 motors arent very torquey, but ls motors arent very horsepowery, hahahaha</TD></TR></TABLE>
Who needs vtec to make power.... LS/Turbo is about the best bang for the buck in B-series swaps....
91c-rex_si
114
Sep 3, 2010 09:50 AM
strsi
16
May 23, 2006 07:04 PM
G2ILS
Jan 30, 2005 12:03 PM
Mr. Travis
Apr 7, 2004 08:30 PM
