possible to swap front disc brakes to rear on 91 crx si?
Old Jul 18, 2001 | 07:24 AM
WuShu's Avatar
New User
Default possible to swap front disc brakes to rear on 91 crx si?
Im considering upgrading to a 4piston caliper for my front, could i then replace my stock front calipers to my rear for added stopping power? is this possible?
Old Jul 18, 2001 | 08:58 AM
RyanR's Avatar
Default Re: possible to swap front disc brakes to rear on 91 crx si? (HondaCRX)
No, it's not possible, the front caliper mounts in front of the hub whereas the rear mounts behind it. Well I guess you could if you got some custom stuff done. But you don't really need it. Just get some good pads for the rear and that should be fine.
Old Jul 18, 2001 | 09:57 AM
eg6ajk's Avatar
no stoping power is gained with rear 4 piston upgrade, even the super heavy race cars, do not usually have more then 2 pistons in the back why, because rear only does about 25-35% of all the braking on the car....
but if you are looking for something custom, check with http://www.fastbrakes.com, brian....he posts on the board....i belive he even has a new kit coming out...also he has 11" kit for the back...
ekcivicdreams
15
Aug 13, 2014 07:42 AM
specificcivic
Dec 14, 2006 11:22 AM
classciv
16
Jun 9, 2006 05:21 PM
R91Si
Nov 13, 2002 03:32 AM
