my input shaft is wobbling and leaking how do i fix?
Unfortunatly, you have to split the trans in order to replace the bearing/seal.
Not hard, but very time consuming if its your first time doing it. Also, the input shaft bearing is pretty much impossible to remove with hand tools.. Anything else in the trans you can do yourself.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rioninja »</TD></TR><TR><TD CLASS="quote"> Also, the input shaft bearing is pretty much impossible to remove with hand tools... </TD></TR></TABLE>
i actually can pop that thing off from the front of the tranny tru the clutch side with a metal bar and a hammer.... u gotta replace that bearing anyways if u have it open..... and it comes nicely off..... thanxs to Mista bone for that trick....
so its the main bearing and seal. and i crack open the tranny pop out the main bearing and replace the seal.how much is the main bearing and seal?whe can i get them?any suggetions for a first timer?
haukurn
Transmission & Drivetrain
May 22, 2011 07:50 AM
prelude182
Aug 3, 2009 05:53 PM
blackfrohatch
14
Jan 5, 2003 05:40 PM
