Is there a way to figure out what FPR I have?
Old Jun 6, 2003 | 07:29 PM
BodyKits NW's Avatar
Default Is there a way to figure out what FPR I have?
I was curious if there was a way to figure out what FPR I have. I have a stock FPR, but I am not sure if it came from a b16 or b18. I have heard that the b18 FPR produces a slightly higher pressure? Is there a way to tell?
Old Jun 6, 2003 | 08:29 PM
boosted hybrid's Avatar
Default Re: Is there a way to figure out what FPR I have? (BodyKits NW)
I have around 15 different fuel rails from h22a's, b18's, b16'a, d16's, d15's, etc they are all externally the same. The spring that is located inside of the fpr is what is going to give you the higher base fuel pressure. There isnt any external marking so that you can visually identify what you have. The two ways that I know to measure your base fuel pressure would be either a fuel pressure gauge, or find the spring rate of the spring inside the fpr and calculate the fuel pressure at cranking from that.
Old Jun 6, 2003 | 08:44 PM
porsche997dc2's Avatar
Default Re: Is there a way to figure out what FPR I have? (boosted hybrid)
Hey, boosted hybrid
which fpr from what model, is best to use?
Old Jun 6, 2003 | 09:07 PM
That's what I thought. I was thinkin the same, thing, but wanted to make sure. THANKS!
EFjoe91
Engine Management and Tuning
Jan 7, 2011 10:54 AM
flat-blk-HB
Jul 29, 2005 08:06 PM
J.R.
Mar 18, 2003 04:38 PM
evil_elmo
Oct 14, 2002 01:26 PM
CM-R
Feb 9, 2002 02:06 AM
