jun 3 owners take a look inside please....
Old Jun 6, 2003 | 03:36 PM
junya16's Avatar
Default jun 3 owners take a look inside please....
setup is in my sig, just curious as to what fuel pressure and what injectors and fuel pump is most highly reccomended..i just ordered a walbro 255lph cause i'm using an ls pump right now and i'm also running stock ls injectors...should i try and get my hands on some obd1 prelude injectors or do u think the fuel pump will take care of the fuel issue?
Old Jun 6, 2003 | 05:01 PM
advanracing62's Avatar
Default Re: jun 3 owners take a look inside please.... (junya16)
B16 stock bottom, JUN III head, I/H/E- Venom pump and injectors and it STILL runs rich.... I know it's different than what you have, but I though I'd atleast respond. I'm running FPR @ 46ish WOT....
Old Jun 6, 2003 | 07:37 PM
Dual Cams's Avatar
the new fuel pump you're getting would make the motor run alot more rich than before.... how high is your compression and do you have hondata or anything like that??
Old Jun 6, 2003 | 10:56 PM
Chubz's Avatar
Default Re: jun 3 owners take a look inside please.... (Dual Cams)
the big problems with JUN IIIs are the fuel needs to be tuned accurately with them, believe me I know. Just on fuel tuning alone i gained 30 more peak whp 180-210
Old Jun 7, 2003 | 12:33 AM
Calavera's Avatar
Default Re: jun 3 owners take a look inside please.... (DeadWrong)
what did you use to tune?
Old Jun 7, 2003 | 12:50 AM
ill phil's Avatar
Default Re: jun 3 owners take a look inside please.... (Calavera)
Is your GSR block a b17 since your car is 2nd gen or is it B18c? Just wondering, helps determine c/r.
Old Jun 7, 2003 | 12:53 AM
JDMb18civic's Avatar
i think you should use the prelude injectors...
now im using RC310 with a 195 walbro and my fuel pressure is set at stock since im using a stock gsr FPR...o yea i have a tuned hondata
Old Jun 7, 2003 | 01:21 AM
junya16's Avatar
Default Re: jun 3 owners take a look inside please.... (JDMb18civic)
ya i'm runnin a b18c block and i believe my comp is 11:5:1 and i'm runnin a vafc and once i get the pump and the prelude injectors i'm gonna try and lean it out a little in the high end and see what that does for me.....this all motor forum is nice
Old Jun 7, 2003 | 03:11 AM
wHOAlly's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMb18civic &raquo;</TD></TR><TR><TD CLASS="quote">i think you should use the prelude injectors...
now im using RC310 with a 195 walbro and my fuel pressure is set at stock since im using a stock gsr FPR...o yea i have a tuned hondata</TD></TR></TABLE>
u have a 255lph monkey ***
Old Jun 7, 2003 | 09:10 AM
rainmanEK's Avatar
big strong guy
Default Re: jun 3 owners take a look inside please.... (Sp00n'd Supra)
Stock DOHC Fuel Pump and Stock DOHC injectors Will work up to 200WHP or maybe little more!
Eric
Old Jun 7, 2003 | 10:56 AM
wHOAlly's Avatar
Default Re: jun 3 owners take a look inside please.... (rainmanEK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rainmanEK &raquo;</TD></TR><TR><TD CLASS="quote">Stock DOHC Fuel Pump and Stock DOHC injectors Will work up to 200WHP or maybe little more!
Eric </TD></TR></TABLE>
yea, but u will have to up the fuel pressure, works, but i wouldnt recommend it, spend money on a nice set of 270's atleast, if not 310's if your pushing 200+ whp
Old Jun 7, 2003 | 01:18 PM
junya16's Avatar
what are the obd1 prelude injectors rated at?.....340cc????
Old Jun 7, 2003 | 04:16 PM
Chubz's Avatar
tuned with hondata
Old Jun 8, 2003 | 01:19 AM
junya16's Avatar
dead wrong did you have better luck leaning it out up top or what?
Old Jun 8, 2003 | 05:24 PM
Chubz's Avatar
gotta be lean on top, to much fuel was killing me
Old Jun 8, 2003 | 06:13 PM
junya16's Avatar
thanks
Recaro
Apr 23, 2014 08:04 AM
junya16
Feb 25, 2004 09:04 PM
W.Zero
Dec 12, 2002 03:08 PM
