JRSC SMOG TEST???????????
hi can anyone help me out. i have jrsc, aem intake, and tanabe racing medallion. will my car past a smog test cuz i need to get one. anyone out there got jrsc that has gotten one would be much help. thanks.
probably not. smog laws are really strict. you might need a ref to check out the motor before you get the certificate. all you can do it test it out.... go to a smog, or ask someone.
the forced induction alone should make you above emissions... dont take my word on it though. ive seen a boosted ls/vtec hatchback pass smog down here in socal.
i believe the jackson supercharger is legal in ca as long as its the 6 psi and i believe your bolt on are legal , just make sure everthing has carb numbers and everthing is hooked up
Technically, you should pass, as the JRSC kit is CARB exempt. What that means is you will pass the visual inspection. However, I have heard of several JRSC ludes not passing the sniffer.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HondaHomie »</TD></TR><TR><TD CLASS="quote">thanks guys. if i dont pass do u know any shops that would do an illegal smog?? located in so cal area. 626. thanks for the help.</TD></TR></TABLE>
like anyone is going to tell where a illegal smog shop is over a public forum...
