I know its been asked before but I couldnt find anything specific (teg dash swap)
Before you flame me I have searched and posted and nobody will sell me a black gen 5 dash for my civic, I do know where I can get a hold of a full GSR dash for a pritty good price, cluster and all.
I have learned most of the swap (I think) making the side mounts and cutting the dash (or the stearing collum) to make it fit .. I have found merrits site with the wiring for the gauge cluster, What other wiring is needed ? does anybody have any diagrams ? Is there anything I missed ? Thanks !
i have the swap which i got from my stripped out teg. all we cut was the material behind the cluster. we used the heater core, ac unit,integra wiring, and fuseboxes(inside and under hood) which made it pretty much plug and play. also used the steering wheel(not sure if we used the srs anymore) and tilting column.
i still have to work on the door panels(mating a civic/teg together so i can use the power switches). still also have the gap between the armrest/shifter pieces.
also do a search because there was a thread on here for the pinouts for the gauge cluster if you decide to go with the stock wiring harness. hth.
so, what kind of wiring had to be done .. I know the cluster has to be redone .. what else needed to be rewired ? thanks !
B18Cej1
Feb 11, 2004 03:31 PM
