.82 or .48 turbine AR
Old Jun 6, 2003 | 09:58 AM
FlySi's Avatar
Default .82 or .48 turbine AR
right now i have a .82ar exhaust housing, ya i kinda got gayed and was told it was a .62 when i bought it
i can get a .48 for a good deal right now... . are there even any advantages to a .82? currently running a stock b16. i read on here that .82 can be good on 1.8L's and i have an LS block sitting in my garage, but with the build i wont be revving past 8000 rpm.
so .82 or .48? or wate around for a .62 for cheap
Old Jun 6, 2003 | 10:21 AM
symba's Avatar
Default Re: .82 or .48 turbine AR (FlySi)
have you run the turbo in your car yet or is it just sitting there? if so, when did it spool or reach full boost?
deciding on a turbine a/r is really just personal preference. Do you want fast spool(without overspinning turbo) or do you want big time top end with much lag.
Old Jun 6, 2003 | 10:27 AM
t04s's Avatar
Default Re: .82 or .48 turbine AR (symba)
On a stock b16 I would go with an all around .63 housing.
Old Jun 6, 2003 | 10:39 AM
LiLOtaku's Avatar
what size is the compressor housing? and what trim is it as well?
I personally will be using a .48 a/r with a t04e 52 trim. This turbo will still make power up top as well. You just wanna make sure you get as much "usable" power out of your turbo for your setup. If you plan on using the LS block later on, i would buy the .63 a/r housing. The .63 will be a good medium for both the b16 and the LS setup.
Old Jun 6, 2003 | 10:44 AM
FlySi's Avatar
Default Re: .82 or .48 turbine AR (LiLOtaku)
its a to4e 50 trim i think....
have not run it in my car, between jobs right now just trying to piece it all together
edit: i was looking at getting a greddy kit origionally, but you cant beat custom setup on cost i was thinking the .48 would spool up quickly like the greddy kit, but from what you guys have said so far i will probably look for a .62
Modified by FlySi at 8:10 PM 6/6/2003
Modified by FlySi at 8:40 PM 6/6/2003
Old Jun 6, 2003 | 11:37 AM
legendboy's Avatar
I will trade you a mint .63 housing for your .86 I really want the bigger housing to go with my 1.9L. Let me know if your intrested.
EDIT: there is no such thing as a .62 turbine housing
Old Jun 6, 2003 | 11:38 AM
FlySi's Avatar
Default Re: .82 or .48 turbine AR (legendboy)
yes i am intrested.
also how do you tell what trim the compressor is.. i think it might be 50 trim there is 50 stamped inside the compressor
Old Jun 6, 2003 | 11:42 AM
legendboy's Avatar
you have to physicaly measure the compressor wheel. The diameter of the exducer (large side) and measure the inducer (small side), squaring both numbers and dividing the smaller by the larger. this gives you a decimal, which is your trim
Old Jun 6, 2003 | 12:45 PM
egg's Avatar
egg
that .82 turbine is a complete waste on your stock B16, i would trade it for something smaller unless you plan on building your motor.
Old Jun 6, 2003 | 12:50 PM
azboy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by legendboy &raquo;</TD></TR><TR><TD CLASS="quote">you have to physicaly measure the compressor wheel. The diameter of the exducer (large side) and measure the inducer (small side), squaring both numbers and dividing the smaller by the larger. this gives you a decimal, which is your trim</TD></TR></TABLE>
Old Jun 6, 2003 | 08:04 PM
FlySi's Avatar
Default Re: .82 or .48 turbine AR (azboy)
ok so with a rough measure of it id say its right around .50 and the compressor AR = .50
is this good bad or ugly
the more i learn about turbos the more i think the one i have sux
Old Jun 6, 2003 | 08:14 PM
project dc2's Avatar
ok, lets talk trim now, wat does it meann ?? n' what does it do, air flow // power ? etcc. tahnks
Old Jun 6, 2003 | 08:16 PM
Dee's Avatar
Dee
A/R and trim explained
SpOonEdOuTeK
Nov 29, 2003 07:52 PM
toxicshit
Oct 30, 2003 01:36 PM
bluedelsol
Jun 14, 2003 11:37 AM
1tyme
Oct 20, 2002 03:18 AM
fire7882
Sep 23, 2002 09:47 AM
