D16A6 9psi JRSC w/stock injectors...?
Old Jun 6, 2003 | 09:45 AM
Zeppelin's Avatar
Default D16A6 9psi JRSC w/stock injectors...?
I have been running this setup for the last 47K miles and it runs well with no problems. At 95psi of fuel pressure at 9psi boost there is a potential for a problem, but all has been well.
My question is... Is there more power to be had by going to larger injectors and an aftermarket ECU?
Old Jun 6, 2003 | 10:36 AM
RyanEJ8's Avatar
Default Re: D16A6 9psi JRSC w/stock injectors...? (Zeppelin)
How much whp?
Old Jun 6, 2003 | 10:52 AM
gitwidit's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Zeppelin &raquo;</TD></TR><TR><TD CLASS="quote">I have been running this setup for the last 47K miles and it runs well with no problems. At 95psi of fuel pressure at 9psi boost there is a potential for a problem, but all has been well.
My question is... Is there more power to be had by going to larger injectors and an aftermarket ECU?</TD></TR></TABLE>
Using an aftermarket ecu and tuning would help you optimize a/f ratio and timing, I'd say that should produce more hp.
Old Jun 6, 2003 | 11:56 AM
Zeppelin's Avatar
Not sure how much hp, never had it dyno'd. Just figured it would cost $1500 - $2000 for injectors/ECU/Tuning, there would have to be alot more hp on tap for me to invest that kind of money.
em1_sir
12
Oct 18, 2007 08:01 PM
top end tuner
Sep 24, 2007 08:41 PM
1SickHb
Dec 9, 2005 08:13 AM
APEXI Si
Jun 22, 2003 09:50 AM
The-LS
May 1, 2003 08:00 AM
