LS Crank in a b16? (Theorys, Deck plates, Strokers)
I know the stroke is 12mm longer but what is the deck height of a b16 and b18? What size deck plate would have to be run if any? I know crower make a stroker kit for a b16 that turns it into a 2.0 ltr (WOW!!!) so what is in the kit and what is the stroke of the crank?.
thanks
mike
thanks
mike
If the crower stroker kit was to creat 2.0 L of displacement and keep the 81mm bore, the stroke would have to be ~97mm.
I think there is a 7mm difference is block height between the B16 and the B18 block. B18B/C block = 270 mm B16A block = 263 mm.
EDIT: I just looked at the Crower site. The 2.0 L stroker kit had a 89 mm stroke and you have to resleeve and bore to 84 mm.
Modified by joe_bocc at 10:16 PM 6/8/2003
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16b2b »</TD></TR><TR><TD CLASS="quote">i know of a guy here locally who had that stroker kit...i'll try to find out a little more about it. 2.0L!!!!! that'd be right niice....</TD></TR></TABLE>
You're right, a 2.0 L engine is damn nice. 2.0 L out of a B16A without a deck plate is stupid.
so you guys say that it can be done? b16=81 mm bore and 77mm stroke... so with just a ls crank and of course rods pistons you can stroke it to 1.8. There must be no problems with clearance of any sort.
thanks
thanks
the oil squirters must be bent/adjusted to clear the crank counter wights. Also you would have a HORRIBLE R/S ratio...6000rmps doens't sound too fun.....
we were running a 89mm crank w/82mm bore 12-5-1 comp pistons
in a crx h-f had to notch the block and remove the oil squirters but the
displacement was
Number of Cylinders are = 4 to 1
Piston Diameter = 82.000 Millimeters
Piston Oversize = 0.000 Millimeters
Engine Stroke = 89.000 Millimeters
Computation Results:
Computed Engine Displacement (CID) is 115
Computed Engine Displacement (Litres) is 1.9
Computed Engine Displacement (CC) is 1880.1
this kit was built by skunk-2 way back in 99-00
the same kit used in there allmotor integra when they were running a b16a w/higher compression of course..
our best et before the motor had to be rebuilt was 12.86@104 w/stock head...
Modified by allmotorb20vtec at 7:02 PM 6/9/2003
displacement was
I have a built b16 i haven't assembled yet....and i also have a few ls blocks laying around...what all would it take to stroke it to a 1.8. i'm wondering if i would be able to use the forge pistons i have now or not....the way the motor is built right now i'm looking at around 10.6 comp.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by filtereds0ul »</TD></TR><TR><TD CLASS="quote">what are you talking about? stock ls's redline is higher than 6000</TD></TR></TABLE>
a stock LS will have a better R/S ration than a B16 w/LS crank. short rods+long stroke=low redline.
hi im selling a all motor B18c5 powered CRX if intrested email or call me $7200 or trade (954)554-2640 if realy intreted take a look https://honda-tech.com/zerothread?id=540229
