I don't want to pull my handle up anymore!
Old Jun 6, 2003 | 06:47 AM
silver99's Avatar
Default I don't want to pull my handle up anymore!
OK, I have a 99 DX coupe and I don't have power locks. I have been lifting the handle inside the car before I flip the lock mech. and it drives me nuts. On the pass. side, you don't need to lift the handle to lock the door. Is there something that I can do to make the drivers side door lock mimic the pass side door lock?
Old Jun 6, 2003 | 06:52 AM
t0p_sh0tta's Avatar
Default Re: I don't want to pull my handle up anymore! (silver99)
It's the same way with power locks. The door must be closed in order for them to operate properly. I have an Ex and I lock my doors the same way as you.
Old Jun 6, 2003 | 06:55 AM
silver99's Avatar
Default Re: I don't want to pull my handle up anymore! (t0p_sh0tta)
See the thing is that the pass. side does not work like the drivers. So with the drivers door open, you can lock the door from the inside by holding the handle up and moving the lock back. On the pass. side, with the door open, you don't have to hold the handle up. So, what I want to do is make the drivers do what the pass. side does. Does anyone know what needs to be done?
Old Jun 6, 2003 | 06:57 AM
t0p_sh0tta's Avatar
I believe that this feature is built into the latching mechanism. You cannot get rid of it.
eghonda's Avatar
this was done purposely by Honda so as to make it harder to lock your keys in your car. everyone has to deal with it...
Old Jun 6, 2003 | 07:41 AM
silver99's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by t0p_sh0tta &raquo;</TD></TR><TR><TD CLASS="quote">I believe that this feature is built into the latching mechanism. You cannot get rid of it. </TD></TR></TABLE>
Are you sure of this? Could I possibly get a Pass. side lock only and make it fit the drivers? As in take it apart?
Old Jun 6, 2003 | 07:57 AM
PotatoePAPA's Avatar
Default Re: I don't want to pull my handle up anymore! (eghonda)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eghonda &raquo;</TD></TR><TR><TD CLASS="quote">this was done purposely by Honda so as to make it harder to lock your keys in your car. everyone has to deal with it...</TD></TR></TABLE>
I kind of like this...just like the annoying *** beeping. Its saved me a lot of times from leaving my keys.
Old Jun 6, 2003 | 07:58 AM
civictypenos's Avatar
get a alarm,add keyless entry to it,problem solved plus you damn well need an alarm.
Old Jun 6, 2003 | 08:03 AM
SikofFalln's Avatar
Default Re: I don't want to pull my handle up anymore! (civictypenos)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civictypenos &raquo;</TD></TR><TR><TD CLASS="quote">get a alarm,add keyless entry to it,problem solved plus you damn well need an alarm.</TD></TR></TABLE>
That's what I did!
Old Jun 6, 2003 | 09:07 AM
silver99's Avatar
That's a good idea, and I should do it. I have had car with alarms and they still get broken into and **** jacked. I have other methods to avoid theft. Plus I live in an apartment complex and when people pull in and hit their button it drives me nuts!
But does anyone ACTUALLY know how this works?
Old Jun 6, 2003 | 09:09 AM
Ricey McRicerton's Avatar
Yup, also what I ended up doing...well worth it!
Old Jun 6, 2003 | 09:20 AM
Philip's Avatar
Default Re: I don't want to pull my handle up anymore! (Ricey McRicerton)
keyless entry is going to be expensive since you don't have power locks
Old Jun 6, 2003 | 09:41 AM
silver99's Avatar
Default Re: I don't want to pull my handle up anymore! (Philip)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Philip &raquo;</TD></TR><TR><TD CLASS="quote">keyless entry is going to be expensive since you don't have power locks</TD></TR></TABLE>
Yea, I didn't think about that.
Little rant on the side - I know there are other options that I could go with, get keyless entry, door poppers, alarm, just deal with it, lock from the outside, etc..
And while these are all great suggestions, I would really like to know if anyone has been able to get around it or not.
Old Jun 6, 2003 | 09:46 AM
Philip's Avatar
this is what i would do:
take apart the thing and seem how it works. if it is possible to modify it to make it similar to the passenger latch, get out the dremel and start cutting. i don't think it would be that simple, but it's worth a try. i don't think you could use a passenger latch, because it would be backwards. do older civics do this too? maybe you could get an older civic's door latch/lock thingie.
Old Jun 6, 2003 | 09:53 AM
wilsel's Avatar
All hondas are this way so no other latch will work
Old Jun 6, 2003 | 09:54 AM
BlackNoise's Avatar
Default Re: I don't want to pull my handle up anymore! (wilsel)
Americans are lazy.
Old Jun 6, 2003 | 09:58 AM
sammysnakes's Avatar
you seem stressed out by this. are you really that lazy?
Old Jun 6, 2003 | 10:29 AM
Bigjon
Guest
Posts: n/a
If your poor you can get a keyless entry from http://www.commandocaralarms.com for 45 bucks and the power door lock modules are like 8 dollars a pair on ebay. It isnt that expensive.
Old Jun 6, 2003 | 10:40 AM
silver99's Avatar
Default Re: I don't want to pull my handle up anymore! (chainsaw)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chainsaw &raquo;</TD></TR><TR><TD CLASS="quote">you seem stressed out by this. are you really that lazy?</TD></TR></TABLE>
Yup
Vic3261
Honda Civic (2001 - 2005)
Jun 17, 2020 10:00 PM
Jimi Hondrix
14
Sep 3, 2015 04:09 PM
romes591
Feb 22, 2008 03:15 PM
incredteg3
Dec 29, 2004 10:16 AM
HondaVtec139
Jul 7, 2002 12:05 PM
