Anyone Dyno these Cams?
Old Jun 6, 2003 | 06:30 AM
cleanEG's Avatar
Default Anyone Dyno these Cams?
Just curious if anyone has dynoed the new cams by RS Machine....and if so, can you post it...Thanks!
Old Jun 6, 2003 | 10:44 AM
ExospeedAMcrx's Avatar
Default Re: Anyone Dyno these Cams? (cleanEG)
I'll get the dyno sheets from RS this weekend. Hope to post them up on our site by monday.
Also, we are doing a project LS/V that we are using these same cams. Once the motor is broken in, we'll install these cams.
Old Jun 6, 2003 | 11:24 AM
cleanEG's Avatar
Default Re: Anyone Dyno these Cams? (exospeedAMcrx)
cool thanks....now Rich showed me a dyno of an ls/vtec but I was curious if anyone had any others...
I picked some up for my setup and in about 4 weeks when the car is back together I will post some dyno sheets then too..
Thanks!
Old Jun 6, 2003 | 11:54 AM
b19coupe's Avatar
What cams do you have now? Perhaps you could post a before and after dyno?
Old Jun 6, 2003 | 12:29 PM
cleanEG's Avatar
Default Re: Anyone Dyno these Cams? (b19coupe)
I had the 98 spec ITR cams in a stock GSR block/head with bolt ons...I will post before and after...just may be a while ...
Old Jun 6, 2003 | 02:05 PM
AllMotorMadness's Avatar
Dyno Sheet shows RS Cams made 6 more hp and 9 lbs. of tq. more than the skunk stage 3's. But a friend tested them on his car and actually gain 8 more hp over the skunk 3's.
Old Jun 6, 2003 | 02:11 PM
cleanEG's Avatar
Default Re: Anyone Dyno these Cams? (AllMotorMadness)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AllMotorMadness &raquo;</TD></TR><TR><TD CLASS="quote">Dyno Sheet shows RS Cams made 6 more hp and 9 lbs. of tq. more than the skunk stage 3's. But a friend tested them on his car and actually gain 8 more hp over the skunk 3's.</TD></TR></TABLE>
Thats awesome! If its not a secret...what was his setup and final numbers?
Old Jun 6, 2003 | 04:39 PM
J2turbo21's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b19coupe &raquo;</TD></TR><TR><TD CLASS="quote">What cams do you have now? Perhaps you could post a before and after dyno?</TD></TR></TABLE>
Hey you should use them in your test your gonna do at IB's.
Old Jun 6, 2003 | 05:23 PM
b19coupe's Avatar
Default Re: Anyone Dyno these Cams? (J2turbo21)
The thought crossed my mind, know anyone with a set to lend?
Old Jun 6, 2003 | 06:28 PM
kungfuSiR's Avatar
Anyone have specs on these cams?
Old Jun 6, 2003 | 06:47 PM
ill phil's Avatar
Default Re: Anyone Dyno these Cams? (kungfuSiR)
Yeah- anymore info and pricing on these cams?
Old Jun 6, 2003 | 09:46 PM
cleanEG's Avatar
Default Re: Anyone Dyno these Cams? (ill phil)
Call RS Machines http://www.rsmachines.com they will have all of the info.....the price is around 760 for the cams...
Old Jun 7, 2003 | 05:25 AM
google's Avatar
do they have these cams for the h22
Old Jun 7, 2003 | 08:18 AM
cleanEG's Avatar
Default Re: Anyone Dyno these Cams? (1320in11)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1320in11 &raquo;</TD></TR><TR><TD CLASS="quote">do they have these cams for the h22</TD></TR></TABLE>
check this thread out https://honda-tech.com/zerothread?id=517727&page=2
Old Jun 7, 2003 | 11:04 AM
H22ek4's Avatar
Are these cams for race applactions only, or is it streetable?
Old Jun 7, 2003 | 03:51 PM
all_engine's Avatar
Default Re: Anyone Dyno these Cams? (H22ek4)
I would imagine if they are comparing these cams with stage 3 cams for diffrent companies they are probably not streetable!!!!
Old Jun 8, 2003 | 09:23 AM
smokey2.0's Avatar
Default Re: Anyone Dyno these Cams? (all_engine)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by all_engine &raquo;</TD></TR><TR><TD CLASS="quote">I would imagine if they are comparing these cams with stage 3 cams for diffrent companies they are probably not streetable!!!!</TD></TR></TABLE>
that sucks, but it was expected!
Old Jun 8, 2003 | 11:44 AM
Tbone's Avatar
Default Re: Anyone Dyno these Cams? (smokey2.0)
I had the specs on the rs cams , there only 12.mm lift. They were like 470 lift on intake and 450 on exhaust, I 'll have to look for where i wrote down the duration specs.
Old Jun 8, 2003 | 07:00 PM
cleanEG's Avatar
Default Re: Anyone Dyno these Cams? (Tbone)
btw...the cams are streetable according to RS......but I will let you know how it goes when I get my motor back in the car...
hondaboyB18C1
Feb 15, 2006 10:38 AM
untuned
11
Jul 2, 2003 03:44 PM
GIANT
Feb 6, 2003 12:28 PM
