locate power steering belt..
Old Jun 5, 2003 | 09:10 PM
abstracvision's Avatar
Default locate power steering belt..
I have a 99-00 civic ex and I need to locate my power steering belt, but I have no idea where it is. Does anyone know where it is?
Old Jun 6, 2003 | 12:16 AM
ShakesTheKlown's Avatar
Default Re: locate power steering belt.. (abstracvision)
Get a haynes manual... On my 95 it's on the right side of the engine (when looking from the front) connected to the power steering pump. Find your power steering fluid reservoir and follow the lines...
Old Jun 6, 2003 | 06:05 AM
egNYC's Avatar
Default Re: locate power steering belt.. (ShakesTheKlown)
should be simple... just look at engine you should be only able to see 3 belts on the right side of the motor. The one that has a small fluid reserve connected to it is you pw. the one that head back near the firewall is your alt and the one goin to under the pw is you ac compressor. If not you can stop by autozone or mechanic i bet they will show you where it is.
92LXcb7
Mar 14, 2012 08:57 AM
4DoorBanger
18
Jul 13, 2011 01:20 PM
16yroldekownr
Jul 4, 2008 06:28 PM
Scud
Dec 29, 2006 09:28 AM
