gsr cluster install
alright.. i have a 97 gsr gauge cluster and a 94-01gsr gauge cluster plugs.. im not to sure what year
(it's from a jdm integra) i dont know if that makes a difference cause all the wires were the same.. everything works except for..
1. the blinker arrows stay on at all times.
2. when i use the blinker the tach, speedo, and temp gauge jumps back and forth, and the high beam indicator blinks with the blinker..
3.when i turn the high beam on it doesnt light up in the cluster.
4.the fuel gauge moves slowly to e. and when i try it somewere else it goes all the way full.
5.temp gauge does not work.
6. backround light do not turn on when i turn on the lights..
if you say do a search im gonna kick ya in the nuts! i have researched it for about a month!!
i went to this site
http://www.geocities.com/cinq1....html <--- this was no help at all and now because of it my hazard button does not work
i went to everything the search archive had on it and still no luck but i may have a solution to the fuel guage..
thanks for your help it is much apreciated!!
(it's from a jdm integra) i dont know if that makes a difference cause all the wires were the same.. everything works except for..1. the blinker arrows stay on at all times.
i went to this site
what car is this going into? Some of the wiring is different. I did this into my 2000 civic. If everything is jerking back and forth when you turn on your blinkers then your ground on the C plug is in the wrong spot. Take the black ground wire and on the back of the cluster trace where the ground should be. After that you should be able to start fixing things just refer to the back of the guage cluster. Trace all the wiring on the cluster, it is a perfect map for any wiring problems you might have. Later
thanks for the help.. so the ground on the 13 pin plug is what my problem is? so by fixing that everything will be good?
oh yeah! its not a fuse either.. and its goin into a 92 cx
thanks
thanks
alright i looked at it again had everything wired right and still didnt work right.. so i put my old cluster back in till you guys can help me figure this stuff out.
thanks
thanks
ok what you need to do is go to honda and have them copy the pages of the wiring diagram for your STOCK cluster.
then from there take the wiring layout that i have on my site (posted above) but do not pay attention to the wire colors. the wires are different on yours so you will have to use both sources to get it installed.
message me if you need anything else
