replacing headlight bulbs
Old Jun 5, 2003 | 06:06 PM
kliq's Avatar
Default replacing headlight bulbs
ok its time to replace the stock bulbs and im wondering is there a way to change the driver side bulb without taking the bumper / housing off? on an EG
i know it can be done on the passenger side but there's not much room on the driver side. is there an easier way? pls support my laziness
cheers
Old Jun 5, 2003 | 06:08 PM
t0p_sh0tta's Avatar
Default Re: replacing headlight bulbs (kliq)
Same procedure as the passenger side. If you have power steering, the fluid resivor can be lifted out of the way.
Old Jun 5, 2003 | 06:22 PM
92SiB18C1's Avatar
Default Re: replacing headlight bulbs (t0p_sh0tta)
Don't forget to replace your JDM headlight fluid too.
Old Jun 5, 2003 | 06:27 PM
NA EJ1's Avatar
Default Re: replacing headlight bulbs (92SiB18C1)
be sure to touch the new bulb all over with your fingers...j/k
just lift your p/s fluid bottle off the bracket and it should be a cinch
Old Jun 5, 2003 | 07:03 PM
kliq's Avatar
Default Re: replacing headlight bulbs (NA EJ1)
sweet thanks for the replies. didnt know the reservoir can be taken out...
ohh and the jdm headlight fluid is still on half..so im good for another couple of months
JDM Approved
Oct 20, 2008 03:59 PM
thecrackerjack
Lighting
Sep 9, 2007 05:38 PM
asgqwaeg
May 5, 2006 05:32 PM
sittingonROTAS
Nov 1, 2005 05:04 PM
firstacura
Aug 13, 2004 08:17 PM
