pintle type injectors vs. rotary disc injectors
Old Jun 5, 2003 | 02:59 PM
D-Man's Avatar
Default pintle type injectors vs. rotary disc injectors
Does anybody know if there is an advantage of running one type over the other?
Old Jun 5, 2003 | 06:46 PM
Phoenix GSR's Avatar
Default Re: pintle type injectors vs. rotary disc injectors (D-Man)
a pintle injector provides a better spray pattern from what I understand, but a disk injector can not be locked from pressure..
so, disk is better for fmu setup and pintle is better for lower pressure setups i.e. standalone/hack/etc
Old Jun 5, 2003 | 06:54 PM
D-Man's Avatar
Default Re: pintle type injectors vs. rotary disc injectors (Phoenix GSR)
A pintle type is safe to how many fuel psi..I heard 60psi,think that's right?
Old Jan 10, 2004 | 12:20 AM
integra-modder's Avatar
anyone have more information on this?
http://www.victoryperformance....injec
I was looking at that site and just want to know if they are **** or if they are as good as pintle injectors.
Old Jan 10, 2004 | 02:40 AM
Default Re: pintle type injectors vs. rotary disc injectors (integra-modder)
I found this written by a staff member of RC Engineering.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">Peak and hold injectors are fired at 4 to 6 Amps, through a ballast resistor, and then fold back to 1 - 2 Amps for the duration of the injection event. They are also known as "fold back" Injectors. Peak and hold injectors are faster responding than Saturated injectors by as much as 1 to 1.5 Ms. They are activated with more power at opening than the saturated types (4-6 Amps vs. .75 -1 Amp.). Peak and hold injectors will maintain injection delivery, cycle to cycle, continuity more accurately than the saturated type. This is particularly true and even more important in high-pressure (75 - 100+ PSI) systems. The higher Hydrostatic loading at excitation requires more amperage to initially activate the injector solenoid and properly maintain complete opening. Peak and hold systems are more expensive to manufacture because they require one computer "injector driver" per injector in most applications. This is a design requirement in Sequential Fire Systems where each injector is fired at a very precise, pre determined, time in the 720 degree 4 stroke processes. P&H injectors are also wound with copper wire instead of brass wire. </TD></TR></TABLE>
What do you guys think? Is what he saying biased or true?
Modified by integra-modder at 10:27 PM 1/10/2004
Old Jan 10, 2004 | 01:19 PM
ttt
integra-modder
Jan 16, 2004 06:50 AM
integra-modder
Jan 12, 2004 09:10 AM
oday
Aug 6, 2003 02:10 PM
PyroVTEC
Jun 27, 2003 12:59 PM
DelsolVtec18
Sep 27, 2001 03:38 PM
