Top Speed?
Just curious if anyone can verify what the top speed of our cars is with stock wheels, tires, gearing, motor, etc. On a closed test track called Nevada I recently hit 142 and was at about 7700-7800rpm in 5th but had to back off because of cars, anyways it seemed to be pulling still so I think it is gear limited not aerodynamic, is there an ecu speed limiter or just gearing? thanks.
on a slight downhill (very slight), i saw 150mph on my speedo....tires are new in the front, so it should be close to correct? (150 is pretty good...my S2000 shows 157mph on the same exact place....once again, who knows if the speedo is correct)
Scot
Scot
