My set up all Most Done, Looking for 400whp what do you think.
Ok heres my complete set up. Im taking the car to torin to have it set up and tuned. Its in a show car for the rest of the season till my sponcerships run out them its goin in to my 93 cx. Its currently in my 93 sol SI.
1995 Integra Gsr Swap
Block Sleved with Darton sleves 84.
Block Decked and Closed
84mm JE Pistons 9-1 Compression
Eagle rods H-Beam
Crower Turbo Cams,
Crower Dual Valve Springs
Crower Retainers
Crower Valves
Port-No Polish
New Oem Rod, Main Bearings
Honda Engine Gasket Set
Cometic Head Gasket-Turbo
New Oem Water Pump
Pro Drive Oil Pump Gear
Skunk2 intake Manifold Ported
Holley 68mm Throttle Body
850cc Injectors
AEM Fuel Rail
AEM Cam Gears
AEM FPR
MSD Rev Control Ing Box
MSD Ext Coil Cap
MSD Blaster SS Coil
MSD Wires
NGK BRK7 Plugs
Rev Hard Cast Steel Tubular(no AC)
Rev Hard NUTEC T04E Hybrid Turbo
Rev Hard Intercooler
NEW Turbo Smart 7psi.
Vortec Blow Off Valve
High Volume Fuel Pump
Centerforce Satge 3 Clutch
ITR lsd.
My p72 with Hondata s100 with the boost option.
Turbo xs Dual stage Boost Controler.
3 bar map (do not have one yet )
This is what i currently have. I am running the car now with the stock gsr injectors, and the boost gauge reads 5psi at full boost. I just want to hit 400whp on the dyno for this year till im done with the hatch. Im ordering the s100 this week and turbosi has offered to put it in for me. so the above is what my set up will be when i go to the dyno. am i missing anything?? thoughts??
Just trying to make sure im set before i get out there. I know im kind of new to H-T but this is my set up, upstatecivic, zc_crx,mpir3, all know me and my car. Thanks!!
Eagle rods H-Beam
Crower Turbo Cams,
Crower Retainers
Crower Valves
Port-No Polish
New Oem Water Pump
850cc Injectors
AEM Fuel Rail
AEM Cam Gears
AEM FPR
MSD Ext Coil Cap
MSD Blaster SS Coil
MSD Wires
NGK BRK7 Plugs
ITR lsd.
im no genious, but i dont think 400whp is going to be a problem with tuning
you have no problems hitting 400. Upgrade the turbo and it will be a lot easier.
You do plan on running race gas with that right?
my setup is similar to your setup. i have 450hp at 14psi. i can e-mail you my setup and picture, if you want to check it out.
Just a Update, I have Lucas 850cc Injectors and the resistor box. Turbo XS dual Stage Boost Controler, gm 3 bar map, hondata s100b gettin installed before i go see torin. I anticipate tossing the cel code 1 for my o2. I have a bosch o2 and i was told im going to need a wideban o2. I have been talking to FULLRACE.COM for there Turbo, Pro Street Manifold for my set up. Not sure if im going to have that on for the tune. Im getting the cars timing set back to stock b/c i have no clue where its at now. Then Im going to make my appt with torin for the dyno and street tune. My cars running perfect after 2 months of trouble after the build. I did this all my self after the build and have no turbo experience in the past. But I cant wait
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by intekragsr »</TD></TR><TR><TD CLASS="quote">you have no problems hitting 400. Upgrade the turbo and it will be a lot easier.
You do plan on running race gas with that right?</TD></TR></TABLE>
No need to upgrade, that turbo is effective to 450 whp at 22-24 psi
He will have to run race gas to reach 400whp
