doing Drag turbo install now. need help
this is for a '00 prelude. how do you route that pipe into the hole?
thanks
Modified by Cowboy at 7:17 PM 6/5/2003
Modified by Cowboy at 7:23 PM 6/5/2003
thanks
Like that .... You are using a PHP parsed URL you don't need this "&file=pipe2.jpg".
BTW, that looks like a drilled hole fopr the pipe routing a 180-Deg ben should fit in there with ssome modif.
Modified by Honda4CX-T at 6:08 PM 6/5/2003
if that's the car i think it is......use a dremel and you have to cut the actual metal out of the hole....you'll know what it is once you look there......pretty simple.....the smallest cutting wheel did that can you believe it.....
ok, i got it in after an *** load of grinding.
now it looks like the pipe is too tall and i don't think the hood will close. should i cut it down and couple it with a silicone joint, because it's originally one whole piece going from intercooler to turbo. or is there something else i should do?
thanks
thanks
When putting a drag 3 kit with a large spearco intercooler on a 93 coupe with b18c1 is there mods to make for the intercool???
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbocivic4 »</TD></TR><TR><TD CLASS="quote">When putting a drag 3 kit with a large spearco intercooler on a 93 coupe with b18c1 is there mods to make for the intercool???</TD></TR></TABLE>
You will most likely have to "cut/modfy" your bumper support frame to acomodate a larger than normal IC. Plus customize the way you will route the piping as well.
MikeMAN
Feb 27, 2003 08:46 PM
