What do you guys think about this all motor set up?
Old Jun 5, 2003 | 08:06 AM
The Crow's Avatar
Default What do you guys think about this all motor set up?
I'm thinking about getting a hatch for a second car and building an all motor b18c for it. What do you guys think about this? What kind of power do you think it will make?
b18c1 block
ctr pistons
stock rods
2 layer headgasket
p&p b16a head
ctr cams
itr valvesprings
Hondata
DC itr header
Modified by The Crow at 12:21 PM 6/5/2003
Modified by The Crow at 12:22 PM 6/5/2003
Old Jun 5, 2003 | 09:57 AM
NSX Bob's Avatar
New User
Default Re: What do you guys think about this all motor set up? (The Crow)
My guess: 180 peak whp, 125 ft lbs.
Old Jun 5, 2003 | 10:09 AM
martini's Avatar
Default Re: What do you guys think about this all motor set up? (Type R Bob)
My guess is a little more. 190whp, 130 ft/lbs
Old Jun 5, 2003 | 10:12 AM
vtecvoodoo's Avatar
Future Texas Boy
Community Builder
hondata
Old Jun 5, 2003 | 10:47 AM
The Crow's Avatar
Default Re: What do you guys think about this all motor set up? (martini)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by martini &raquo;</TD></TR><TR><TD CLASS="quote">My guess is a little more. 190whp, 130 ft/lbs</TD></TR></TABLE>
I was hoping for a little more than 190whp.
Old Jun 5, 2003 | 11:26 AM
AllmotorJunkie's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by The Crow &raquo;</TD></TR><TR><TD CLASS="quote">
I was hoping for a little more than 190whp. </TD></TR></TABLE>
Only one way to find out! Do it! Dyno it!
Old Jun 5, 2003 | 12:47 PM
badCRX's Avatar
New User
Default Re: What do you guys think about this all motor set up? (AllmotorJunkie)
Probably need 310cc injectors.
Old Jun 5, 2003 | 12:56 PM
zad5's Avatar
i dunno too much but wont that be too much compression for ctr cams? i know that ctr piston in a gsr head will up the compression but not sure with a b16 head and with a 2 layer gasket. why ctr cams i think you should change cams and depending on cash get a better header like smsp, header tech, hytech and skunk2 intake manifold.
Old Jun 5, 2003 | 01:09 PM
The Crow's Avatar
Default Re: (zad5)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zad5 &raquo;</TD></TR><TR><TD CLASS="quote">i dunno too much but wont that be too much compression for ctr cams? i know that ctr piston in a gsr head will up the compression but not sure with a b16 head and with a 2 layer gasket. why ctr cams i think you should change cams and depending on cash get a better header like smsp, header tech, hytech and skunk2 intake manifold.</TD></TR></TABLE>
The reason I want to use the ctr is because of the midrange power those cams can make. I've seen 200whp with an itr header.
Old Jun 5, 2003 | 02:51 PM
Charlie Moua's Avatar
Default Re: (The Crow)
i was thinking only about 185whp at most!
Old Jun 5, 2003 | 06:09 PM
Mr Hammond's Avatar
a/k/a Jomo
You want midrange? Get some TODA A's. B's would work nicely with that set-up. Enough compression.
Old Jun 5, 2003 | 06:20 PM
The Crow's Avatar
Default Re: (Mr Milano)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr Milano &raquo;</TD></TR><TR><TD CLASS="quote">You want midrange? Get some TODA A's. B's would work nicely with that set-up. Enough compression.</TD></TR></TABLE>
I've seen the ctr cams make more midrange power than the Toda's. Plus this will be a daily driver, Toda's break stuff. Do you think the compression will be to much for the ctr cams.
Old Jun 5, 2003 | 06:34 PM
Mr Hammond's Avatar
a/k/a Jomo
I've seen the ctr cams make more midrange power than the Toda's. Plus this will be a daily driver, Toda's break stuff. Do you think the compression will be to much for the ctr cams.</TD></TR></TABLE>
In a cat's eye. Daily driver? Break stuff? Well I could put Toda A's in your car and you would never know it by the idle, but you sure as hell would by the gains over CTR cams in the mid-range and followed up by the raped ape pull to the redline. The rumors and lie's about Toda's breaking stuff and not idling are just that. Install error and tuning error. Please stop adding to them alright? You wanna talk about Toda's and how great they actually are. Talk to Jack @ P1 auto. How about streetable VTEC killers? Yeah that's right....
Old Jun 5, 2003 | 07:48 PM
The Crow's Avatar
In a cat's eye. Daily driver? Break stuff? Well I could put Toda A's in your car and you would never know it by the idle, but you sure as hell would by the gains over CTR cams in the mid-range and followed up by the raped ape pull to the redline. The rumors and lie's about Toda's breaking stuff and not idling are just that. Install error and tuning error. Please stop adding to them alright? You wanna talk about Toda's and how great they actually are. Talk to Jack @ P1 auto. How about streetable VTEC killers? Yeah that's right....</TD></TR></TABLE>
Toda cams are too expensive for a second car. As for Toda having the best midrange....
BLUE LINE; 220.9 HP, 141.7 TQ =JUN 3
RED LINE; 208.3 HP, 141.1 TQ =Type-R
GREEN LINE; 215.2 HP, 135.6 TQ = Toda C
Note the color's of the torque lines for each cam. The JUN 3's torque at 8,000 RPM are clearly 5+ lbs of torque higher than either the Type-R or Toda Cams. The Toda Spec C's started to surpass the Type-R cams in HP and TQ at about 8100 RPM.
Old Jun 5, 2003 | 07:49 PM
NSX Bob's Avatar
New User
I've seen the ctr cams make more midrange power than the Toda's. Plus this will be a daily driver.</TD></TR></TABLE>
I daily drive Toda B's and CTR pistons, among other parts. Just build it right and there shouldn't be a problem.
Old Jun 5, 2003 | 07:59 PM
All Motor Rex's Avatar
You should get 200whp. I made 204 with itr cams & pistons. Good Luck.
Old Jun 6, 2003 | 05:52 AM
The Crow's Avatar
Default Re: (All Motor Rex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by All Motor Rex &raquo;</TD></TR><TR><TD CLASS="quote">
You should get 200whp. I made 204 with itr cams & pistons. Good Luck.</TD></TR></TABLE>
That's what I was hoping for to get.
Old Jun 6, 2003 | 06:26 AM
B16GSR's Avatar
almost identical setup i will be running with the exception of i am using a ls crank and rods for the torque and toda or skunk cams, and a header tech header. i want over 200 whp daily driven for the street just to have fun, hopefully about 140 lb or torque to boot, with a itr tranny with an jdm final sould be very fun
Old Jun 6, 2003 | 03:45 PM
junya16's Avatar
190whp max w/ amazing tuning
Old Jun 7, 2003 | 03:09 AM
Casey's Avatar
Default Re: What do you guys think about this all motor set up? (junya16)
I basically had this setup, here was mine:
c5 block
ctr pistons
mugen head gasket
(this brings cr between 12.5-13:1)
ctr cams
cai
dc header
test pipe
tanabe rm
cam gears
vafc
fpr
It was tuned on 93 octane. The only time it knocked was around 3500-4k. Im sure with hondata you can pull it off. I believe my timing was at 14 or 15. I never did a compression and leakdown test, so my #s could be off bc of it, but I made 180/129 with a nice midrange(Pulling v8s is cool on the hwy ) On the other hand, Chris(thats his HT screename) made 195/135 open header with just fpr tuning with a near identical setup
Old Jun 7, 2003 | 09:14 AM
rainmanEK's Avatar
big strong guy
Default Re: What do you guys think about this all motor set up? (Casey)
CTR cams will limit your Peak WHP, They are great cams for Close to facotory Setup!
I dont belive the power differnce will be worth the headache Between CTR pistons and JDM ITR or P30 Pistons! The CTR pistons will limit Timing to 16 deg. btdc or Less!
I would reconsider Setup By using Little Less compression and Little Larger Cams (IE...Skunk Stg. 1, Toda Spec A)
Eric
Old Jun 7, 2003 | 10:13 AM
fast4doorgsr's Avatar
my motor is almost the same.if you have the money spend it on your head, thats were the power is.i talked to eric at erics racing and he's the man so i listened to him.i have a gsr motor which i got the comp. port and polish job from erics kept my rods used jdm itr pistons,skunk2 valves,springs and retainers,cams also{stage 2}.eric said it's best to stay with the same brands as far as springs,cams go that where he seen the best results.i got a lightened flywheel and underdrive pulley.skunk2 intake manifold erics racing throttle body and an aem cold air intake. v-afc to tune with and a p28 programed by erics.with a itr tranny eric said i will be around 215-230 whp if tuned well.i dont have a/c or power steering.i haven't dynoed yet but ill post when i do with a graph.
Old Jun 7, 2003 | 10:20 AM
that SCION girl's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Type R Bob &raquo;</TD></TR><TR><TD CLASS="quote">My guess: 180 peak whp, 125 ft lbs.</TD></TR></TABLE>
I had this setup....thats about what it made ....
Old Jun 8, 2003 | 01:03 PM
Lost Type R's Avatar
Default Re: What do you guys think about this all motor set up? (allmotorgurl)
throw in some cams gears and an aftermarket throttle body
Old Jun 8, 2003 | 02:37 PM
The Crow's Avatar
Default Re: What do you guys think about this all motor set up? (Lost Type R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lost Type R &raquo;</TD></TR><TR><TD CLASS="quote">throw in some cams gears and an aftermarket throttle body </TD></TR></TABLE>
I forgot about cam gears. That's a must!
