Stock Tach in 4g prelude vtec is going crazy.
Old Jun 5, 2003 | 07:37 AM
vtvj's Avatar
Default Stock Tach in 4g prelude vtec is going crazy.
i have a 94 Prelude VTEC, and the stock tach when at idle just sits at 1600 rpms, and doesn't move, even though the car is idling normally, then on occassions it'll jump up to 6900rpm, and just get stuck there for no reason..
can you guys help?
thanks.
Old Jun 5, 2003 | 08:29 AM
PreludeRacer023's Avatar
Default Re: Stock Tach in 4g prelude vtec is going crazy. (vtvj)
mines doing the same thing...cant figure it out
Old Jun 5, 2003 | 08:48 AM
Prelude Vtec 23's Avatar
Default Re: Stock Tach in 4g prelude vtec is going crazy. (PreludeRacer023)
Have you guys messed w/ any of the wires lately? Mine did that and I found it to be that one of the wires was grounding out.
Old Jun 5, 2003 | 11:31 AM
vtvj's Avatar
Default Re: Stock Tach in 4g prelude vtec is going crazy. (Prelude Vtec 23)
someone today, on another forum told me to check the light blue wire that's inside the distributor, he said more then likely the contact on that terminal is dirty/loose.
vnt
Old Jun 6, 2003 | 03:17 AM
vtvj's Avatar
which wire?
thanks
Old Jun 6, 2003 | 08:56 AM
93LudeVtec's Avatar
Mine did the same thing, my mechanic replaced the distributor module and it has been jus like new ever since.
Old Jun 6, 2003 | 09:10 AM
Sephro's Avatar
Default Re: Stock Tach in 4g prelude vtec is going crazy. (93LudeVtec)
yeah same here. First tach started going crazy next day car stalled distributor was no good. Replaced it and perfect since.
Old Jun 6, 2003 | 10:07 AM
prelittlelude's Avatar
yeah check the blue wire, its the tach signal wire coming from the distributer, if that is messed up your tach won't read a RPM, another check would be to see if your Cruise control works becasue this also uses the tach signal fromteh distributer, thought the a breakage in teh wire could be somewhere up by the gauge, and ur cruise will still work
Old Jun 9, 2003 | 09:54 AM
vtvj's Avatar
Default Re: Stock Tach in 4g prelude vtec is going crazy. (prelittlelude)
great...i'll check it out.
vnt
evoluti0n12
10
Jul 30, 2009 01:53 PM
Longchamp
Mar 28, 2009 02:38 PM
92integracer
Oct 15, 2008 12:58 PM
Dropped90Integra
Jan 13, 2005 08:57 PM
its WANG yoO
Dec 9, 2003 09:19 AM
