Can someone explain this picture
Old Jun 5, 2003 | 05:48 AM
sshaikh01's Avatar
Default Can someone explain this picture
I want to make an emulator so i can pass inspection for my secondary o2 sensor.
I don't understand this chart.
Does anybody has any instructions.
Old Jun 5, 2003 | 05:55 AM
NinetyNineSI's Avatar
Default Re: Can someone explain this picture (sshaikh01)
its pretty self explanitory. there is a legend down below, the 2 pc boards are what you use to mount the resistor and capacitor. id assume it would only cost just a little more to get a real o2 sim though. take into consideration that this thing will be subjected to heat and moisture. although the home made sim may work, id recommend the real thing. check out jacobs electronics or ebay. hope this helps
Old Jun 5, 2003 | 06:08 AM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: Can someone explain this picture (NinetyNineSI)
stillen has one now as well they sell with the headder for the Spec V i know its nissan but it is an o2 emulator nontheless.
Old Jun 5, 2003 | 06:36 AM
sshaikh01's Avatar
I need it to work only for an hour, just so i can pass inspection.
The 02 sensor at auto zone is 80 bucks.
Old Jun 5, 2003 | 07:37 AM
Roller_G's Avatar
Won't work because if you have a CEL already and you try to reset the ECU then the ECU goes into default values. It looks for speed checks, braking, and other variables. Until those are unlock the ECU will respond back to their computer stated it's code locked. If the 02 sim doesn't work(more than likely) then it will have a CEL again after xx miles. Best thing to do is buy a real 02 sim.
boosted civi
Mar 10, 2009 07:15 PM
goldjdm
Oct 8, 2007 07:00 PM
HONDA RR
Sep 16, 2005 03:53 PM
Slow*Jim
Honda S2000
Sep 13, 2005 07:43 PM
VTC_CiViC
Jun 20, 2002 12:37 PM
