Nitrous ? from the squeezers
Old Jun 5, 2003 | 04:24 AM
madhatch's Avatar
Default Nitrous ? from the squeezers
I have been running a #30 NOS jet for about 1 year now. On a website for fprds I found a chart for what jet is which shot. The # 42 is a 75 shot on the chart. Has anybody ran a 75 shot in a sohc and had succes. I have over 30,000 miles on my setup wuth the 30 jet. it was a 40 shot according to the chart. Just wondering. I figure I will give it hell I have a spare now and I also almost have the rest of the money for my real swap....
If anybody is runing it let me know where you have your timing. I run -6 plugs 1 step colder and I am at normal (factory) timing now.
Old Jun 5, 2003 | 04:37 AM
mildly.interesting's Avatar
Default Re: Nitrous ? from the squeezers (madhatch)
I've been spraying 75 on a D16 for 25,000 miles now, and never detonated once. I run Bkr7e plugs, 16 DEGREES!!! of timing, and 100 octane in every tank. I think you could get by without the 100 octane, but you probably should stay at least with 93. I ran 16.9 on the motor... but w/ the 75, I ran 14.6-14.8 consistently. I will say thats on Azenis, with Eibach drag launch springs, and ES motor mounts, if you think that might make a difference.
I sprayed 50 on mine for about a week, but when you've got that little pill in your hand, you think "aw man, it won't hurt to put another 25 on it"
I've also got to say that I fill my bottle up on an average of every 2 weeks, but I do get it for $2.20 a lb...
Old Jun 5, 2003 | 08:29 AM
madhatch's Avatar
2.20 a pound I pay 4 bucks here
Old Jun 5, 2003 | 09:37 AM
JdmVetteEater
Guest
Posts: n/a
Default Re: (madhatch)
I spray a 75 shot.... here is a dyno chart of it untuned.... the red is nitrous... didnt know what the pressure was and didnt have a bottle heater at the time...
Old Jun 6, 2003 | 06:52 AM
madhatch's Avatar
you af goes to crap @ and after 65, I bet with a good pump and a riser you could sqeuuze more out of it.
Old Jun 6, 2003 | 07:17 AM
tek_civic's Avatar
yeah i would go with a FPR but i ddon't think the fuel pump is necessary. maybe slightly bigger injectors. run a little rich to help avoid detonation when you spray it. gl!
Old Jun 6, 2003 | 09:29 AM
madhatch's Avatar
Default Re: (tek_civic)
if it blows I will put in my swap early
XzIpK
May 13, 2007 07:16 PM
bootlegtrader
Apr 16, 2006 03:46 AM
SiR831
Jun 28, 2005 10:19 AM
HotImportNightHonda
Sep 23, 2004 09:43 AM
Griff
Jul 16, 2004 11:36 AM
