How many of you guys burn oil on your fully built cars?
I have a built gsr motor and i need to add oil every 500 miles or so. It eats like a court of oil in 500 miles. Is that norimal?? Je pistons 84mm. p.s. its running all motor right now.
From: 99th level of hell, where all roads only go straight, where curves go to die. Houston Texas
I don't burn any, but I sure do leak it!
btw, what's a "court" of oil?
i leak oil too, but not very much.
I burn a small amount of oil through the turbochargers exhaust seal, but i belive this to be mostly normal, because it's not a precision or turbonetics, it doesen't have the stepped seals. Precision turbos have theese, correct?
im not sure how much i burn, but is very minimal. a quart every 500 doesen't sound right.
dont be a dick, i meant a quart. and nothing is smoking out of the exhuast its just that the oil level drops. Anyone else have any input?
Haven't driven it in so long... But I was burning/leaking a quart ever 20 miles for some time.
Mostly leaking because the oil filter bolt that went through the oil cooler backed off some. Oops. BAD ENGINE BUILDER!
I burn about the same amount. I have the same size block... 2 litre with 84.5 pistons. Im not sure what the actual problem is but I was told that it is normal for new motors to go through a little bit extra oil. hope that helps some.
hmm i don't think thats normal ethier. You sure you don't have a small leak somewhere? try throwing a clean white towel under the car for a night after you just ran it and see. Any oil on your spark plugs? Have a friend follow you as you drive and see if its smoking out of the exhaust, it may not burn it at idle. Otherwise i'm sure a leakdown test would show if there was a internal problem or not.
good luck.
good luck.
my problem was too much oil blow by. I wasn't burning the oil cause it was going out of my breather valve before the combustion could go at it.
maybe your rings haven't sat right or shittiy install.
fernando.
33
May 1, 2009 09:28 AM
tommy.
13
Mar 28, 2006 03:51 PM
HybridGSR1
Jul 4, 2003 07:37 AM
