B18C 1/4 mile times in EG
Old Jun 4, 2003 | 08:06 PM
Rukusmasta2's Avatar
Default B18C 1/4 mile times in EG
what do u guyz think i would run with this setup in a gsr b18c
ctr cams, skunk2 cam gear, dc header, aem short ram, itr im(or any better suggestions), msd ignition, and thermal cat back. and what mods do u have done and some times. please help tryin to get some ideas
Old Jun 4, 2003 | 09:03 PM
b19coupe's Avatar
Default Re: B18C 1/4 mile times in EG (Rukusmasta2)
ITR IM will not bolt to the GSR head without some modification. Skunk2 IM works and flows very similarly to the ITR manifold. You will probably be in the high to mid 14's, decently tuned.
Old Jun 4, 2003 | 09:07 PM
gsrvx's Avatar
New User
Default Re: B18C 1/4 mile times in EG (b19coupe)
I would say low 14/high 13 probably. I've done 14.2-14.4, gsr motor, i/h/e in an eg.
Old Jun 5, 2003 | 04:26 AM
GOLDBERG's Avatar
Default Re: B18C 1/4 mile times in EG (RK)
put ctr pistons in that b18c1 also because ityll bump compression up to 12.0
Old Jun 5, 2003 | 08:47 AM
g5r's Avatar
g5r
Default Re: B18C 1/4 mile times in EG (GOLDBERG)
i have seed 14.6-15.0 eg with b18c1 i/e semi gutted.
Old Jun 5, 2003 | 09:10 AM
sammysnakes's Avatar
mid to high 27s.
Old Jun 5, 2003 | 10:17 AM
AllMotorDC2's Avatar
I'm certain you'll be in the high 13's on slicks. I've been 14.30's in a EK with just I/H/E. Plus that's in a 2600+ lbs. coupe.
Old Jun 5, 2003 | 06:19 PM
Mr Hammond's Avatar
a/k/a Jomo
Default Re: B18C 1/4 mile times in EG (AllMotorDC2)
Try the Drag Racing forum. I am so tired of these bench racing threads. Go run and find out. That set-up could get you anywhere from low 13's to 30's man.
Old Jun 5, 2003 | 09:24 PM
BluePrintmfg.com's Avatar
Banned
Default Re: B18C 1/4 mile times in EG (Mr Milano)
B18c stock bottom end, p&p B16 head ITR manifold, in a daily driver EG 12.7 w/CTR cams. That is a very cheap set-up!
Old Jun 6, 2003 | 08:09 AM
yaya's Avatar
Default Re: B18C 1/4 mile times in EG (11sec.ALL MOTOR)
omg thats all the mods? your not missing anything?
ive seen a gsr stock block, itr milled head ctr cam run 13.8 in a car loaded with **** 93 cx on street tires
Old Jun 6, 2003 | 09:17 AM
Slappy's Avatar
Default Re: B18C 1/4 mile times in EG (yayaRl337)
My buddy has a EG HB full int. with 99 GSR swap, AEM CAI,CTR intake cam, JDM header, clutch, chipped P28, and drag radials, open exhaust. He ran 13.6 motor. Then added a NX 100 shot and ran 12.3. Sorry I cant remember his MPH. BTW that is stock block, heads never been off.
Old Jun 6, 2003 | 09:55 AM
gzrmoto's Avatar
we ran a stock gsr with ctr cam and modified gsr im 13.5
Old Jun 6, 2003 | 11:10 AM
owen_the_soyboy's Avatar
Default Re: B18C 1/4 mile times in EG (gzrmoto)
14.XXX
Old Jun 6, 2003 | 08:27 PM
EVLTEK's Avatar
Depending on the altitude.
13.5-13.8 depending on weight and rubber.
Few guys over here in NZ are running those times, with less mods.
Old Jun 7, 2003 | 04:21 PM
jdm_kenji's Avatar
with the same setup i ran 14.5 @96 mph
Old Jun 8, 2003 | 06:47 AM
Turbo92Si's Avatar
Default Re: (jdm_kenji)
to the guys using the ctr cams, are you using both or just intake cam?
Old Jun 8, 2003 | 10:20 AM
ImportechPerformance's Avatar
Default Re: (Turbo92Si)
14.3 @ 96mph
GSR stock bottom, 97 spec ITR cams, nasty badly bent dc 4-2-1 header and AEM. Non tuned....
IN an EK 4DR! mind you...oh yeah on Falkens...
Old Jun 9, 2003 | 05:09 AM
1bad-eg's Avatar
Low 14's on street tires, high 13's on slicks.
Old Jun 9, 2003 | 09:56 PM
ISELLRIGHTHANDDRIV
Guest
Posts: n/a
Default Re: B18C 1/4 mile times in EG (1bad-eg)
i ran at best on slicks 13.088 at 102.2 mph with my gsr block, b16 head, ctr pistons, ctr cams, itr manifold, itr header, j's racing intake. simple as can be.
anything is possible if you know how to drive your car.
Old Jun 9, 2003 | 10:39 PM
Mentat Ghola's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 11sec.ALL MOTOR &raquo;</TD></TR><TR><TD CLASS="quote">B18c stock bottom end, p&p B16 head ITR manifold, in a daily driver EG 12.7 w/CTR cams. That is a very cheap set-up!</TD></TR></TABLE>
Wow dude, thats just like my setup. Ecxept im runin a b16a IM and ITR cams with chipped PR3 (or will be soon anyway). Thats some good numbers! ANY DYNO #? Im hoping to break into the HIGH 13's with my EF LX.
Old Jun 12, 2003 | 03:46 PM
B18chb's Avatar
i have an eg6 with B18C from japan best time 13.3
Spartanic
14
Nov 23, 2009 01:45 PM
toeknee360*
Jan 29, 2006 11:56 PM
Team 4
Jul 20, 2003 07:21 AM
quikyEG
Apr 24, 2003 07:25 AM
