Having hard time eating fuel.
Car: 98 Acura EL( Civic )
Engine: D16Y8, basically stock
Milage: 110,000km, (68,350 miles)
Problems:
1. Car doesn't start very well even with 10 ~ 15L (2.4 ~ 4 gallon) of gas left in the tank. It starts well if I wait few seconds until the fuel pump stops making sound.
2. The speed changes dramatically on uphill when it's on cruise control.
Things have done to it.
- Fuel system was cleaned last year with Motorvac (I think). It solved the cruise control problem for few days, but came back after
-New Wix fuel filter months ago.
-ok spark plugs (NGK Iridium)
What to do?
-I think the fuel pump need to be replaced
-Clogged injectors?
-Clogged fuel line?
-Would fuel pressure regulator help?
Problems:
What to do?
-Clogged injectors?
-Clogged fuel line?
change your fuel filter, make sure your gas cap is working properly (holding the vacuum).....if you still have the problem, it COULD be your fuel pump
hermtm2
23
Apr 8, 2009 06:17 PM
crnimacak
Apr 21, 2006 10:11 PM
