compression test question
Old Jun 4, 2003 | 05:15 PM
98cwtypeR's Avatar
Default compression test question
I just had a quick question, there's a Type R for sale on thepartstrader going for 12,500. He said his compression test read 195 across the board, is this still a strong motor?
what numbers would u expect to see on a good motor?
Old Jun 4, 2003 | 05:18 PM
BlueR's Avatar
Default Re: compression test question (98cwtypeR)
if he did it right...that sounds like GSR compression
ITRs are usually above 210...
at least its consistent for all 4 cylinders
Old Jun 4, 2003 | 05:22 PM
ithrowpoop's Avatar
Default Re: compression test question (BlueR)
with 34k on the clock mine read 255 across the board.
Old Jun 4, 2003 | 05:24 PM
98cwtypeR's Avatar
Default Re: compression test question (ithrowpoop)
hmmm, his has...83,XXX miles on it...still decent?
Old Jun 4, 2003 | 05:36 PM
markpaco's Avatar
that is fine. Consistency is slightly more important than overall compression. Lets put it this way; I'd rather have 195 across than 210-210-210-180. My experiences put B18C1-5s at 200-210. H22A was about 185-195.
Old Jun 4, 2003 | 08:17 PM
98cwtypeR's Avatar
Default Re: compression test question (markpaco)
oh ok, thanks for the help
Old Jun 4, 2003 | 08:26 PM
VTHokie's Avatar
When you do a compression test you wanna look for consistency, not high numbers. This is because your compression numbers will vary day to day depending on your conditions/location (altitude, temp, etc). So if your numbers are consistent across the board it means your engine has even wear. Usually if a cylinder is off by alot ( i think > 20 variance) then something is wrong with that cylinder. Also your numbers will depend on whether or not you hold the throttle down or not. I did a compression test without holding the gas down and got 210 across the boards, then i did the test again with the throttle down and i got 240 across
Old Jun 4, 2003 | 10:29 PM
Nameless RB26's Avatar
Default Re: compression test question (VTHokie)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTHokie &raquo;</TD></TR><TR><TD CLASS="quote">When you do a compression test you wanna look for consistency, not high numbers. This is because your compression numbers will vary day to day depending on your conditions/location (altitude, temp, etc). So if your numbers are consistent across the board it means your engine has even wear. </TD></TR></TABLE>
exactly.
And hopefully the guy cranked it 6 times @ WOT.
negusjuda
Apr 3, 2013 02:33 PM
stockb18c
Oct 13, 2006 08:52 AM
snowblind7x
Apr 13, 2005 08:12 PM
Mr.Integra
Apr 22, 2004 07:55 PM
MechEng
Feb 11, 2002 06:15 PM
