Quick question on valve specs
Old Jun 4, 2003 | 03:34 PM
KiddEng's Avatar
Default Quick question on valve specs
i pulled these specs out of my service manual for my 98 hx d16y5
Valve clearance (cold):
STANDARD, (NEW)
IN: 0.18 - 0.22, (0.007 - 0.009)
EX: 0.23 - 0.27, (0.009 - 0.011)
my quesiont is, are the "STANDARD" specs the SAE measurment and the "New" specs the MM or vise versa?
Old Jun 4, 2003 | 03:36 PM
SloCivicHMM's Avatar
Default Re: Quick question on valve specs (KiddEng)
I just pulled the specs for my motor
it said
.13 to .17mm intake
.15 to .19mm exhuast
I'm pretty sure the first ones are MM.........
Old Jun 4, 2003 | 03:41 PM
KiddEng's Avatar
Default Re: Quick question on valve specs (SlowCivicHmm)
ok so the "standard" side of the specs is in MM.
crap...gotta go return this feeler gauge for smaller ones
anyone else confirm?
thnx
Old Jun 4, 2003 | 04:23 PM
tek_civic's Avatar
he is right, get the feeler gagues for the second set of numbers, and im told you should go for the lower end of the spectrum.
Old Jun 4, 2003 | 07:30 PM
KiddEng's Avatar
Default Re: Quick question on valve specs (tek_civic)
get feelers for this set? IN (0.007 - 0.009)
EX (0.009 - 0.011)
both in MM
Old Jun 5, 2003 | 04:58 AM
KiddEng's Avatar
^bump^
damn im confused on which spec is which measurement on me
Old Jun 5, 2003 | 06:24 AM
b19coupe's Avatar
The spec is in mm. The spec in the ( ) is in inches.
Old Jun 5, 2003 | 12:05 PM
KiddEng's Avatar
Default Re: Quick question on valve specs (b19coupe)
thanks! cause the other replies it seemed like they were refering to different set of specs and got all confused.
thnks for the heads up
Old Jun 6, 2003 | 04:59 AM
KiddEng's Avatar
ok one last question..well i hope
you're supposed to start on cylinder 1 and follow firing order.
i know you manually turn the crank so that each cylinder will be at the top when u work on that cylinder. but how do i know that cylinder 1 will be at top when i hand turn the crank?
is there a marking somewhere that will let me know that cylinder 1 will be at the top?
thnx
Old Jun 6, 2003 | 05:17 AM
b19coupe's Avatar
I adjust all valves on the heel of the cam, the part of the cam opposite the highest point of the lobe. You want the high lift part facing up, away from the rocker arms. You can tell when # 1 or #4 are at TDC on the compression stroke, because the white mark on the crank will be lined up with the pointer on the lower timing cover. Whichever cylinder (#1 or #4) that does not have any valves open, is the one that is at TDC on the compression stroke. #1 & #4, and #2 & #3 are piston pairs. When #1 is at the top, #4 is at the top, and when #2 is at the top, #3 is at the top.
But you really don't have to worry about all that stuff, just make sure to adjust the valves when the cam is not compressing the valves (on the heel).
BTW, I am too lazy to turn the engine over by hand, I just use a remote starter to bump the engine over.HTH.
Old Jun 6, 2003 | 12:03 PM
KiddEng's Avatar
ok got it...
so is it feasible to adjust #1 and #4 first and then do #2 and #3 since both pairs are at TDC? or do i really have to go thru one at a time 1-3-2-4 ?
Old Jun 6, 2003 | 12:18 PM
b19coupe's Avatar
The pistons are at TDC, but the valves are at different positions. When #1 piston is at TDC on compression, with all valves closed, # 4 piston is at TDC at the end of the exhaust stroke, getting ready to start down on the intake stroke, and all valves are open (overlap).
Old Jun 6, 2003 | 02:58 PM
KiddEng's Avatar
ahh i see, so i do have to go one at a time then.
learning something new everyday!
Old Jun 7, 2003 | 12:16 PM
KiddEng's Avatar
Default ok adjusted them... but got a new set of ???
ok i just got finished adjusting the valves...not that difficult to do as a matter of fact.
my only concern is that it seems i hear more/little louder tapping coming from under the valve cover.
im thinking that when i was using the feeler guage theres supposed to be a "slight drag" on the gauge, which i did. But i think i left it a little too loose? maybe i should adjust the lock nut and pin a little tighter so there is more of a drag on the gauge?
also i noticed that the rocker arm that i was working on has a little play when i was adjusting them. meaning that i can move the arm up and down slightly by pulling or pushing the arm. don't know if this play a part in the tapping.
tomorrow im gonna adjust them again but so that there is more drag and that the arm doen'st move up or down
Old Jun 7, 2003 | 06:10 PM
KiddEng's Avatar
Default Re: ok adjusted them... but got a new set of ??? (KiddEng)
^bump^
im assuming im not supposed to hear alot of excessive tapping right?
going to re-adjust tomorrow.
Old Jun 7, 2003 | 06:14 PM
b19coupe's Avatar
Should not hear excessive tapping, no. Feeler guage should have a slight drag, but not so tight that you have to pull really hard to get it out.
Old Jun 8, 2003 | 09:46 AM
KiddEng's Avatar
Default Re: ok adjusted them... but got a new set of ??? (b19coupe)
and for b19coupe for the help!
only took 1 hr this time around haha! i did have the "drag" concept a little out of whack from yesterday, but this time around i knew what i had to do and it took me less time and was ALOT easier. now my engine purrs so nicely! also gave it fresh oil while i was out there and feels like a new car!
thnx H-T for the help
now time for a
crxguy406
Apr 6, 2013 11:23 AM
all-mtr-teg
Jun 12, 2007 04:43 PM
94integrals
Jul 2, 2004 11:28 AM
ArchAngel Sabastian
Oct 13, 2003 06:59 PM
HondaJon
Aug 3, 2002 12:16 PM
