205 Azenis on 15x8" rim. Yes, it can be done!
Old Jun 4, 2003 | 02:09 PM
Todd00's Avatar
I said I don't want a title!
Default 205 Azenis on 15x8" rim. Yes, it can be done!
For those who think the 205/50/15 Azenis is too narrow for a 8" rim, lookie here.
The fit is perfect and almost as if the tire was made for a 8" rim. Will see if turn-in has improved any this weekend.
Old Jun 4, 2003 | 02:12 PM
Reid's Avatar
Global Moderator
Default Re: 205 Azenis on 15x8" rim. Yes, it can be done! (Todd00)
Any rubbing issues?
Old Jun 4, 2003 | 02:13 PM
io_burn's Avatar
New User
Default Re: 205 Azenis on 15x8" rim. Yes, it can be done! (Reid)
Lookin' good.
(Wish I had the cash to blow on a set of those wheels!)
Old Jun 4, 2003 | 02:17 PM
Todd00's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Reid &raquo;</TD></TR><TR><TD CLASS="quote">Any rubbing issues?</TD></TR></TABLE>
The rear wheel barely hits the upper control arm. A 5mm spacer fixed that. As for driving the car with them on, my springrates are high enough so the suspension doesn't move that much anyways.
Old Jun 4, 2003 | 02:19 PM
Reid's Avatar
Global Moderator
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Todd00 &raquo;</TD></TR><TR><TD CLASS="quote">The rear wheel barely hits the upper control arm. A 5mm spacer fixed that. As for driving the car with them on, my springrates are high enough so the suspension doesn't move that much anyways.</TD></TR></TABLE>
Are you running extended wheel studs in the rear?
I thought the general concensus on using 5mm spacers in the rear of the car, was that it is a bad idea with stock wheel studs.
Old Jun 4, 2003 | 02:25 PM
ScaleExtric's Avatar
I thought the general concensus on using 5mm spacers in the rear of the car, was that it is a bad idea with stock wheel studs.</TD></TR></TABLE>I dont know about on 5 lug setups..but trust me ..even with extended stock lugs...spacers do snap em..ask Jackson..he'll how many encounters he has had with this problem.
Old Jun 4, 2003 | 02:45 PM
bus stop's Avatar
after looking at your pic and see my Azenis (which is on stock wheel)....you really make them look fatty
Old Jun 4, 2003 | 02:48 PM
shane01itr36's Avatar
What is the offset of your wheels?
Old Jun 4, 2003 | 02:49 PM
Wai's Avatar
Wai
ProFunction/GT Motoring
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Reid &raquo;</TD></TR><TR><TD CLASS="quote">Are you running extended wheel studs in the rear?
5mm isn't too bad. Once you get up to 10mm that you would need some extended studs so that the lug nuts would have enough turns. (I think 4 turns in the minimum??)
Old Jun 4, 2003 | 02:50 PM
Wai's Avatar
Wai
Default Re: 205 Azenis on 15x8" rim. Yes, it can be done! (ScaleExtric)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ScaleExtric &raquo;</TD></TR><TR><TD CLASS="quote">I dont know about on 5 lug setups..but trust me ..even with extended stock lugs...spacers do snap em..ask Jackson..he'll how many encounters he has had with this problem.</TD></TR></TABLE>
How would spacer snap lug nuts or wheel studs (extended or not)?? Please clarify.....
Old Jun 4, 2003 | 02:51 PM
Reid's Avatar
Global Moderator
Default Re: 205 Azenis on 15x8" rim. Yes, it can be done! (shane01itr36)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shane01itr36 &raquo;</TD></TR><TR><TD CLASS="quote">What is the offset of your wheels?</TD></TR></TABLE>
15x8 TE37s in 5x114.3 are offered in +27mm (what Chris has) and +45mm (what Todd has).
Old Jun 4, 2003 | 03:02 PM
zer0zer0 TypeR's Avatar
15x8 TE37s in 5x114.3 are offered in +27mm (what Chris has) and +45mm (what Todd has).</TD></TR></TABLE>
So with the +27 offset TE, there shouldn't be any rubbing issues right? (well in theory)
Old Jun 4, 2003 | 03:04 PM
MaxBoost's Avatar
New User
why didn't you just run a thicker tire?? Maybe 215/50/15
Reid's Avatar
Global Moderator
Default Re: 205 Azenis on 15x8" rim. Yes, it can be done! (zer0zer0 TypeR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zer0zer0 TypeR &raquo;</TD></TR><TR><TD CLASS="quote">So with the +27 offset TE, there shouldn't be any rubbing issues right? (well in theory)</TD></TR></TABLE>
I am curious to see how it fits in the fenders of a lowered Integra.
If you have adequate fender clearance, it should fit fine.
.RJ's Avatar
.RJ
Default Re: 205 Azenis on 15x8" rim. Yes, it can be done! (MaxBoost)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MaxBoost &raquo;</TD></TR><TR><TD CLASS="quote">why didn't you just run a thicker tire?? Maybe 215/50/15</TD></TR></TABLE>
show me where you can get a good street tire in that size.....
Old Jun 4, 2003 | 03:06 PM
py1188's Avatar
yeah but you may have to do some rolling of the fenders possibly right??
My question is how badly do you thnk that setup would rub with a 225 tire, both front and rear? Would more than a 10mm spacer be needed in that instance??
Old Jun 4, 2003 | 03:10 PM
Reid's Avatar
Global Moderator
Default Re: 205 Azenis on 15x8" rim. Yes, it can be done! (py1188)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by py1188 &raquo;</TD></TR><TR><TD CLASS="quote">yeah but you may have to do some rolling of the fenders possibly right??</TD></TR></TABLE>
It would depend on ride height. It may need more clearance than simply rolling the fenders gives. Flares may be needed.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by py1188 &raquo;</TD></TR><TR><TD CLASS="quote">My question is how badly do you thnk that setup would rub with a 225 tire, both front and rear? Would more than a 10mm spacer be needed in that instance??</TD></TR></TABLE>
I would stick with a 5mm spacer all around and deal with any rubbing on the rear control arm that you may encounter.
Old Jun 4, 2003 | 03:15 PM
Rodney's Avatar
I forgot more about hondas then you will ever know....
From: hop,skip, and a jump from the city,, new friggin york, USA
lookin' good todd. i still think my hoosiers will look much more pimpier....
Old Jun 4, 2003 | 03:17 PM
JaeOne3345's Avatar
dope but then again im not really suprised seeing how the "205" azenis is wider then your average 205 tire. nice nonetheless
Old Jun 4, 2003 | 03:18 PM
py1188's Avatar
I would stick with a 5mm spacer all around and deal with any rubbing on the rear control arm that you may encounter.</TD></TR></TABLE>
Reid always coming up with the valuable info
I was planning on going to a 15x7, or even 7.5 with an SSR comp, but I was always curious about this 15x8 after I heard some people were going to try it. I tried to order some 15x7 Volks back in the day, but decided to wait and see the outcome of this. If too much modification is needed to run these, I'll probably stick with my idea of running a 15x7
Old Jun 4, 2003 | 03:35 PM
Eric R's Avatar
Any pic of the car with them on?
Old Jun 4, 2003 | 05:19 PM
Todd00's Avatar
After some tweaking, my test fit showed that a spacer was not needed on the front or the rear. However, you'll need a different upper control arm on the rear (like a camber kit control arm) to get this to work. The oem control arm has that lip on it that makes things want to rub.
The front wheel even clears Spoon calipers--barely!
However, some 3mm spacers all around would be about perfect. If this wheel would have been offered in a +42 offset, it would be perfect. the +45 will tuck in the fenders though.
I doubt you'd be able to get the +27 to tuck into the fender. You'd need to raise the car because you'd be rubbing on the fender lip both front and back. I thought about this, but I'd rather have the car lower for my needs, plus I do not want to go cutting fenders. +27 offset with modded fenders and 225/45/15 Hoosiers would rock!
Old Jun 4, 2003 | 06:05 PM
Ausmith's Avatar
Todd - looks good...
Old Jun 4, 2003 | 06:40 PM
Floyd's Avatar
Default Re: 205 Azenis on 15x8" rim. Yes, it can be done! (Ausmith)
Looks pretty good, but I would say 8" is a hair too wide. On a 7.5, the sidewall of the tire is nearly flat, and perpendicular to the road. In your pic it looks like the sidewall flares out a slight bit to seat the bead on the rim. Also, the 7.5 SSRs have no rubbing issues with stock setup.
(BTW, this is not an attempt to ***** another post to advertise my SSRs for sale. Really. )
Old Jun 4, 2003 | 06:46 PM
Floyd's Avatar
Default Re: 205 Azenis on 15x8" rim. Yes, it can be done! (Floyd)
Here's a pic of them on the 7.5"
